I have an Intel I5 4670K and the Corsair 450D case which supports a 360 mm radiator with a top mount I belive. What do you guys recommend with a $50-$80 (maybe a $100 if it's worth it) budget?
http://pcpartpicker.com/part/cooler-master-cpu-cooler-rln28l20pkr1 it is 280mm and will perform well the ony future upgrade would be fans but that would eb for silence
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
a cooler master seidon 240m if you can find one for 69.99 usd and what is your currency
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
usd most likely since ha is using $
ok
I have an Intel I5 4670K and the Corsair 450D case which supports a 360 mm radiator with a top mount I belive. What do you guys recommend with a $50-$80 USD (maybe a $100 if it's worth it) budget?
http://www.amazon.com/Kraken-All-In-One-Liquid-Colling-RL-KRX31-01/dp/B00NC05KFK/ref=sr_1_1?ie=UTF8&qid=1412690152&sr=8-1&keywords=nzxt+x31
A water-cooled mid-tier gaming PC.
corsair h100 (240mm?)
That's out if stock and extremely expensive.
The radiator is a little small. Is that because of my price range?. Does it do a significantly worse job cooling than a larger radiator?
That is one of the best performing AIO around for the price rage you gave at present. Any dual 120mm or 140mm radiator AIO will be $90 - $140 depending on where you buy it and if there is a sale or not. Also, it is not just the radiator you have to worry about with an AIO, the pump is also a big concern and these pumps have less failure rate.
I have the same CPU and Case,  Currently i use a h100i (240mm) This hits nicely with the case and works well for me
Intel i5 4670k @4.5 | 16GB Patiot Viper Xtreme | Corsair H100i | MSI Z87 GD65 | Crossfire x2 Asus 7950 Direct CUII
250GB OCZ SSD | LG Bluray RW Drive | 750Watt PSU | Corsair 450D | Corsair K50 | Corsair M40
