I have an issue on my laptop running Linux:  It runs pretty hot (80-85C) when just browsing, but the fan always runs at a very low RPM, is there a way in Linux to control the fan speed?
Also, I have sprayed air in the vents, how much would it help the temps to open it and clean it and or replace the thermal paste?
https://linustechtips.com/topic/228265-fan-control-in-linux/
The fan is probably dying if it runs slow at 85C
https://linustechtips.com/topic/228265-fan-control-in-linux/#findComment-3124857
Most laptops should make that fan go really fast if it starts to heat up. Sounds like the fan wants to give you the bird.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/228265-fan-control-in-linux/#findComment-3124874
