So im looking to upgrade my cpu to an i5. And I dont know whether to get the 4670k or 4690k.... I found two mobo combos and the 4670k is cheaper but its using a z87 mobo yet the 4690k has a z97 mobo but its more expensive. I need to know if the performance difference is worth the cost.
4670k Mobo combo: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1904261
4690k Mobo combo: http://www.newegg.com/Product/ComboDealDetails.aspx?nm_mc=AFC-TechBargains&cm_mmc=AFC-TechBargains-_-NA-_-NA-_-NA&ItemList=Combo.1904258&cm_sp=
I know my name is bad I made it not thinking I would use it. Just call me dogenut...
https://linustechtips.com/topic/228088-4670k-vs-4690k/
4690k performs better and has a bunch of newer features and like sata express, newer drivers, and a bunch of other features from the motherboard manufacturer.
https://linustechtips.com/topic/228088-4670k-vs-4690k/#findComment-3122626
the 4670k comes with a microATX board and an older chipset.
The 4690K has an ATX board with a new chipset.
The 4690K overclocks better than the 4670k.
You choose.
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
https://linustechtips.com/topic/228088-4670k-vs-4690k/#findComment-3122636
It's clocked slightly higher out of the box, and it has better TIM (Thermal Interface Material), which is basically thermal paste under the IHS (Integrated Heat Spreader; metal bit), so this translates in lower temps, I don't know however how much the temps are dropped.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/228088-4670k-vs-4690k/#findComment-3122642
4690K all the way.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/228088-4670k-vs-4690k/#findComment-3122651
