Hey guys,
So yesterday I got a new monitor and also my psu blew up.
Today I got a new psu and on the box it says there is a 6pin pci connector, and there isn't.
So now I'm using onboard graphics and a hdmi-dvi connector and my new monitor has black lines round the outside.
Really pissed off with this computer.
Is there anything I can do for the black border or is that just a hdmi thing?
https://linustechtips.com/topic/225658-one-problem-after-another/
Hey guys,
first list specs and what psu did you have generic?
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
Try checking in the suite that comes with the display driver... There's usually a setting for scaling I think... I forgot how it looks like on Catalyst since I'm not on my main rig right now...
Sorry about you PSU though... Was it a "Gutless Wonder"?
If the PSU doesn't come with something it advertises on the box, send it back.
And I believe the black bars is something to do with the scaling.
What do they know of England, who only England know?
"Well that's what I always said I wanted to be remembered for, for being honest. Nothing else is worth a damn"
yea thats what im thinking where did he get it from
I have the same problem with the little tiny black border. I got it when I change my monitor and the cable.
"Strength does not come from winning. Your struggles develop your strengths. When you go through hardships and decide not to surrender, that is strength" Arnold
I know a lot of places where I can get Gutless Wonders for around 5-10USD near me...
@jem.graham I'd recommend getting a PSU from a trusted brand instead of cheaping out... A bad PSU can kill your system, kill your cat, and burn your house down... You might've been lucky that the previous one didn't take out your PC wholesale when it blew up, but there's no telling what can happen... Also, cheap PSUs tend to have really bad power delivery and this can kill your parts slowly...
NEVER cheap out on the PSU.
exactly use at least a brand name one a cheep antec with 80+ cna be better than sme generic 80+ gold
My psu was a Chinese thingy, not too bothered about that. Although now, yet another problem.
I try to open catalyst control center to see if there is some form of scaling settings but it wont open, it says:
Catalyst Control Center: Command Line Interface has stopping work
These are the errors given in the error send info thing box
Files that help describe the problem:
  C:\Users\Jem\AppData\Local\Temp\WER47C9.tmp.WERInternalMetadata.xml
  C:\Users\Jem\AppData\Local\Temp\WER6059.tmp.appcompat.txt
  C:\Users\Jem\AppData\Local\Temp\WER6115.tmp.mdmp
hhow much mony do you have for a psu and never never buy non brand name products chinese knock offs are horrible
And yes, I've just bought another cheap thing, £23 for an Ace 550w. Think I might invest in a Corsair or BeQuiet one for my next build in a couple of months
here is a good 35 pound psu http://uk.pcpartpicker.com/part/evga-power-supply-100b10500kr
35 POUNDS!
That's double my 18 pound Black Pug!
^Joke^
It looks like a really reliable PSU, you should get it.
Because he had a hard drive.
What are your full specs? If you're running on onboard graphics, I advise you to uninstall the AMD drivers and install the ones for your onboard graphics (if it's not AMD)...
Never cheap out too much on the PSU... Something at least 80+ bronze certified will be leagues better than a gutless wonder...
I'll have a look at that, thanks :)
welcome  :D
yeah, it could be sn issue with using amd drivers and intel graphics. i would uninstall the amd ones and install the intel ones.
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
I have an AMD cpu, so I don't know which is which
AMD catalyst control center and AMD graphics driver are the ones for the graphics card.
Overscan settings in catalyst.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
