Hi, i am planning to buy Corsair Obsidian 900D to my new rendering workstation. I am concern about few compatibility issues:
1. there is in this case any special mount place for 2,5" SSD? or i need to buy an adapter for eg. from 3,5 to 2,5?
2. Does this case support workstation standard motherboards like Z10PE-D8 WS => EEB Form Factor 12 inch x 13 inch ( 30.5 cm x 33.02 cm ). Because on corsair page in specification it isn't listed (only Mini-ITX, MicroATX, ATX, E-ATX, XL-ATX, HPTX)
And i have one question about Corsair Hydro series. If any corsair hydro product is compatible with Socket 2011 (Intel SB-E & IB-E) it means also that is compatible with newer version 2011-v3 (HaswellE/EP)/EN or no?
https://linustechtips.com/topic/225010-corsair-900d-compatibility-issues/
DO NOT get a 900D for an AIO, or even for custom watercooling, just dont get 900d.
If you REALLY want corsairs signiture blend of lots of fetures, high price tag, and bad build quality, than get 750D, but I would recomend to you instead the entho Luxe, or Primo if you really want.
1. I'm sure it comes with something to mount them.
But velcro, painters tape,double sided tape or just sticking it in the bay works just as well. :D
REMEMBER TO QUOTE SO I GET A NOTIFCATION! Add me on Steam: http://steamcommunity.com/id/Shroomster/ Review(s) more to come
I saw in real life 900D and it looks and feel like high quality build, it has also really good reviews. So what would you recommend as the best case for dual xeon setup (rendering machine). Earlier i've considerd:
Phanteks Enthoo Primo
NZXT ?
Lian Li ?
Rosewill Legacy MX2 (too small)
Nanoxia Deep Silence 6
CoolerMaster Cosmos II
Thermaltake Urban series
InWin 904..(too small)
Fractal Design Define XL
Razer NZXT H440 (too small)
SilverStone Tj11
XFX Type 01
Bitfenix Shinobi XL, Ghost, Shadow, Pandora
Tj11 is by far the best, but overkill
If you're using an AIO, then just get an enthoo luxe, 750D or H440. You don't need a massive case like the TJ11, enthoo primo and 900D if you aren't going to do a full custom loop in it. Also, these cases will have mounting points for 2.5" drives as well as 3.5"drives.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
