Best motherboard for FX-8320/50 sub $130
Solved by Sintezza,
Doesn't matter anyway as I will most likely be going with a 990FX specifically this one http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
i would highly recommend that by the way.
990FX chipsetboards offer indeed allot more pci-e lanes which can be handy for dual gpu setups and what not.
However, its a bit depending if you ever think about sli or crossfire, then it depends on which cards you look at.
Because the FX8350 will bottleneck highend cards in cf/sli
