Hello and is this desktop worth the money? http://pcpartpicker.com/p/pvswD3
It will be my first ever desktop.
My budget:850$
Games i will play on the desktop: Minecraft modded,garrys mod,bf3,etc.
Cpu:
Intel i5 4460 Motherboard:Msi Z97S Sli krait Ram:HyperX Fury White (2x4) Storage:Seagate 1tb/Samsung 850 Evo 120gb Gpu:Gtx 960 2gb sc Case:S340 Black Psu:Corsair Rm 650w 80+ Gold certified
My anime list : http://myanimelist.net/animelist/KRImSIN
https://linustechtips.com/topic/224186-my-first-desktop-build/
My budget:850$
Yes but it's a better idea to get an R9 280, and a better power supply (not higher watts, but better quality, something like Seasonic)
Also, get Hyper 212 EVO for CPU cooler and GA-970A-D3P for motherboard
"Rawr XD"
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3070731
My budget:850$
Then why is there $950 of parts in that link you gave...
Get a better power supply from EVGA seasonic or Corsair.
Corsair CX are pretty good for the price. You can save quite a bit of money.
Also, get windows 8.1 and a hyper 212 evo instead.
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3070734
1. Swap the cooler out for a hyper 212 evo.
2. try pushing for a gtx 970 if you can, its about $340 for most of them, but if you can't then the 760 is fine.
It would work for what you plan to do, good luck!
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3070736
$1030 without rebates.
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3070741
That CPU will bottlneck GTX 760.
Go with build instead:
http://pcpartpicker.com/p/Zrnbyc
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3070760
Your budget 850, the price for the build you'd posted: 950
This would be better to fit in you price range.
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($99.99 @ Amazon)
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard  ($69.98 @ NCIX US)
Video Card: HIS Radeon R9 280X 3GB IceQ X² Video Card  ($259.99 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($38.98 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Monitor: AOC E2260SWDN 60Hz 21.5" Monitor  ($99.99 @ Newegg)
Total: $849.36
Generated by PCPartPicker 2014-09-28 18:13 EDT-0400
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3070768
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($179.99 @ NCIX US)
Motherboard: Gigabyte GA-H97-GAMING 3 ATX LGA1150 Motherboard  ($77.99 @ Amazon)
Memory: Kingston 8GB (2 x 4GB) DDR3-1333 Memory  ($76.99 @ NCIX US)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($65.98 @ OutletPC)
Storage: Western Digital RE3 1TB 3.5" 7200RPM Internal Hard Drive  ($45.99 @ Amazon)
Video Card: MSI GeForce GTX 770 2GB Video Card  ($253.98 @ Newegg)
Case: BitFenix Merc Beta (Black) ATX Mid Tower Case  ($18.99 @ NCIX US)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ Newegg)
Monitor: Acer S220HQLAbd 21.5" Monitor  ($99.99 @ Amazon)
Total: $864.89
Generated by PCPartPicker 2014-09-28 18:16 EDT-0400
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3070799
My budget is 850$ but i forgot to remove the things that costed me over 850$ sorry.
Cpu:
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3070966
Total: $864.89
I need to fit windows 7 64 bit in there.
Cpu:
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3070980
Total: $849.36
R9 280X is it a good graphics card?
Cpu:
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3070988
The R9 280X is a good graphics card, it will be fine for 1080P gaming.
Does it have good fps?
Cpu:
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3071020
Cpu:
https://linustechtips.com/topic/224186-my-first-desktop-build/#findComment-3071779
