That's quite high I would imagine, I don't own an Intel CPU so I'm not 100% sure. What cooler are you using.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3063911
im running prime 95 and im getting temps from 70c to 88c is that okay?
actuallly on one cors its reaching 89c
Provided you're saying this can you take a screenshot from the BIOS & in Windows with Prime95/whatever cpu benchmark + CPU-Z
What kind of settings?
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3063919
Do not run Prime95 on Haswell. Use something like IntelBurnTest or AIDA64 and then tell us what the temps are like.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3063930
even in idle the cores max temps are in the 50's ):
Need to know your voltage settings. Idle 50's is ridiculously high unless you're throwing around 1.3v, if it's at a modest 1.2-1.23 do a remount of the cooler, something's not right.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3071454
I have the 4790k and am running stock cooling.  Ive never ran Prime 95 because i dont personally want to hit those kinds of temps.
So yes those are very high temps if you have an after market cooler ( if youve got a stock cooler those are high temps but expected).  Just remember that prime 95 is DESIGNED to achieve those types of temps on CPU's
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3071522
most motherboard manufacturers within their tuning use "adaptive voltage mode"
which tend to increase heat due to the extra voltage needed to use in synthetic
stress/benchmark apps. most manufacturers say "do not use adaptive voltage
modes when using stress/benchmark," use manual mode for these types of
stress to reduce the voltage/heat output.
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3072385
well i took out the 212 evo and i seen that the thermal paste was messed up so i just put the stock cooler on and the temps range from 30-40 while doing nothing and 50 while doing something and 50-79 while gaming so imma give it a week or 2 and see if i should return the cpu to new egg
I just looked in the uefi and it says its at 1.3v or some shit lol
CPU: AMD Ryzen 9 5900HX GPU: AMD RX 6800M RAM: 16GB  SSD: 500GB NVME
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3073157
Nothing is wrong with the CPU. 1.3v and stock cooler I would expect them to be even higher. You need to change your BIOS settings, as @airdeano has mentioned...multiple times.
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3073812
Prime95 is horrible on Haswell CPU's. Run aida64 or OCCT for proper stress testing.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3074958
Those temps are more to normal with 212.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3076098
I have no idea how to do that and i have a gigabyte gaming 5 mobo
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3078775
If you have no idea how to use your BIOS what would be the point in running Prime95? It's a benchmarking utility, mainly used to benchmark the stability of over clocked CPU's. Your computer will never encounter that kind of stress in any real world scenario.
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3080290
well i was gaming the other day and the core temps got up to 90c  but i finally updated my bios and it took care of that problem the hottest it gets now with the stock cooler is 74c
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3125850
For Prime95 its common to see Temps up into the 80's. Prime95 does not work well with Haswell CPU's. You will get better "real world" performance numbers with using Aida64 or OCCT. But as far as Prime95, 80's are acceptable.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/223667-i7-4790k-temps/#findComment-3127130
