1866 MHz and CL9 vs 2133 MHz and CL11
Solved by DIV1D3,
Because the 2133MHz modules have a higher CAS latency there'd probably be no noticeable difference.
If you can't get the 1866MHz kit than the 2133MHz ones will do fine.
But with an APU the speed would produce more performance because the iGPU uses the system memory as VRAM.
Featured Topics
atxcyclist ·
Posted in Home Theater Equipment0 -
3
ElChales ·
Posted in New Builds and Planning4 -
Gundmi ·
Posted in Troubleshooting0 -
ElChales ·
naldo29 ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
