Decided to finally migrate over from consoles to PC gaming and try my hand building my own. I was going to go the pre-built route, but I think this will pay off even if it's harder. Anywho, I was using the Ultimate 4K gaming video as a benchmark, but $4,000 is a bit steep. So what I'd like to know what is a good rig for 4K gaming around or just north of $3000, preferably less if doable.
Appreciate any help~!
https://linustechtips.com/topic/222311-4k-build-advice/
Do you need a monitor included
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3047007
Location?
Monitor?
Peripherals?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3047008
Gotcha covered m8, give me a second to get some parts together.
http://pcpartpicker.com/parts/partlist/
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3047009
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($93.70 @ Amazon)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($147.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($99.99 @ NCIX US)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card (2-Way SLI)  ($629.98 @ NCIX US)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($88.98 @ OutletPC)
Total: $2334.56
Generated by PCPartPicker 2014-09-25 18:02 EDT-0400
Asus PB287Q 60Hz 28.0" Monitor  ($609.99 @ Amazon)
PSU Tier List | CoC
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3047024
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($234.98 @ OutletPC)
CPU Cooler: Corsair H110 94.0 CFM Liquid CPU Cooler  ($99.99 @ Newegg)
Motherboard: Asus Maximus VI Hero ATX LGA1150 Motherboard  ($165.95 @ SuperBiiz)
Case: Corsair Air 540 ATX Mid Tower Case  ($124.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Monitor: Dell P2815Q 30Hz 28.0" Monitor  ($409.99 @ Adorama)
Total: $2655.79
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3047141
Total: $2655.79
build are great but those monitors wouldn't be great for gaming with the refresh rate and they so expensive at same time in my opinion  , personally  i would get  this http://pcpartpicker.com/part/asus-monitor-vs278qp would be better monitor for gaming with 144ghz refresh rate
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3047196
Total: $2334.56
I agree with this guy, though I'd probably get windows 8.1 instead of windows 7. But then again windows 8.1 vs windows 7 is pretty much preference at this point it seems...
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3047763
just a little something i also put together http://pcpartpicker.com/p/VLGCCJ
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($99.99 @ Newegg)
Motherboard: MSI Z97-Gaming 9 AC ATX LGA1150 Motherboard  ($269.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($145.98 @ Newegg)
Video Card: Asus GeForce GTX 980 4GB Video Card (2-Way SLI)  ($565.91 @ Newegg)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($135.98 @ Newegg)
Total: $2492.71
Generated by PCPartPicker 2014-09-25 19:58 EDT-0400
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3047830
Total: $2492.71
That WD Drive is a massive waste of money.
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3047897
Total: $2492.71
Drop the VelociRaptor down to a 7200 RPM drive and get a bigger SSD if you are concerned about speed (but honestly if 1.25TB of space is enough for you, then scrap the hard drive and just get a 1TB 840 EVO).
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3047963
yea i meant to replace it after i was finished because kinda noticed made no sense to put in such an expensive hard drive that if you sum up its price and the ssd you should almost have enough for 1tb ssd. though my logic at first for 1 250gb ssd was for os and certain programs you want to run fast. the wd hard drive which should of went with cheaper drive it just that the speed is pretty good for just other programs which you don't need an ssd for.
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3048088
4k build advice : Don't do it. Waste of money right now. Wait until GPUs can actually handle 4k at decent FPS/Graphical settings.
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3048832
This. We do not have any GPUs on the market that can handle any multi monitor 4k setups. I have been gaming multi monitor for a while now and will never go back to a single. For single monitor gaming, I am sure there is a decent set of cards that will do the majority of 4K at an average FPS
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3049124
Definitely don't do 4k. A 1440p monitor with a higher refresh rate would be a better idea. Scaling issues will be persistent with 4k until it becomes the standard which isn't likely to happen anytime soon considering the only people who really benefit from 4k are content creators.
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3049435
3 way SLI Of GTX 970 And X99 Can handle 4K Easy
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($299.99 @ Micro Center)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($99.99 @ Amazon)
Motherboard: Asus X99-DELUXE ATX LGA2011-3 Motherboard  ($395.99 @ SuperBiiz)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($109.97 @ SuperBiiz)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card (3-Way SLI)  ($349.99 @ NCIX US)
Case: Corsair 760T White ATX Full Tower Case  ($166.99 @ NCIX US)
Total: $2630.84
Generated by PCPartPicker 2014-09-26 03:30 EDT-0400
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3049898
Experimenting a bit for fun, especially since I'd like to push a little higher than the 3k mark or just about hit it. Anywho, is this a good build and what more needs to be added (if anything) or dropped entirely?
http://pcpartpicker.com/p/dxP4P6
https://linustechtips.com/topic/222311-4k-build-advice/#findComment-3050842
