I'm going to build a new PC very soon, and I need help with the operating systems
Before 5 months I bought a mini laptop for browsering and skype, When I unboxed that laptop I saw a windows CD (x64 bit)
It doesn't have product key but here's the information that is written on the CD :
Microsoft
Intended for distribution with a refurbished PC.
DVD
Includes Service Pack 1
64-bit software
Windows 7 Home Premium
But I have the product key on that mini laptop, can't I use the CD and the product key for my new build?
https://linustechtips.com/topic/220329-operating-system/
Microsoft
DVD
64-bit software
You should be able to yes. Before anyone says you can't those keys on the laptop aren't in use. The manufacturers use a manufacturer key to activate the laptop. Entering a unique key on every laptop would be too tedious and time consuming. So after they use their key they put the key you purchased by buying the computer on the bottom of your laptop. Since it isn't registered with anything you can use it on future machines.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/220329-operating-system/#findComment-3020193
Not without invalidating the Laptop's software. Also, if the motherboard has been replaced in the laptop, you will not be able to activate it probs and you will have to call Microsoft.
I would just buy a new license, or use that software exchange thing on reddit.
And the DVD will work, but it'll come with the Laptop Manufacturer's registry things on it, but no biggie
Compatible with Windows 95
https://linustechtips.com/topic/220329-operating-system/#findComment-3020200
Nope, OEM licenses are attached to the first motherboard that the OS is installed on. The CD should work (IDK tbh), but the product key WILL NOT
Oh, but what happens if I didn't put the product key?
Do you recommend me getting a new OS or just stick with that?
https://linustechtips.com/topic/220329-operating-system/#findComment-3020205
NOPE
oem licence cannot be moved to another computer.
If you judge a fish by its ability to climb a tree, it will live its whole life thinking it's stupid.  - Albert Einstein
https://linustechtips.com/topic/220329-operating-system/#findComment-3020243
If it works by all means go ahead and use that, but if not you can buy Windows 8.1 or Windows 7 really cheaply on g2a.com. I tried using my laptops activation key on my dad's computer and it didn't work.
Corsair 5000D / Intel Core i7-12700KF / Arctic Liquid Freezer 3 360mm / MSI Meg Z690 Ace / RTX 3080 Ti Founder's Edition / 64GB Corsair Vengeance RGB 3200 MHz CL32 / Corsair RM1000X / 1TB ADATA SX8200 Pro (Boot) / 2TB Acer Predator GM7000 Gen 4 (Storage) / MSI MPG271QRX-QD / MSI Mag 274QRF-QD / LG CX 55" / G-Pro Wireless
https://linustechtips.com/topic/220329-operating-system/#findComment-3020257
That's my point, the key hasn't been used. The key will work!
https://linustechtips.com/topic/220329-operating-system/#findComment-3020306
NOPE
Did you even read my post? The key on his laptop is not in use, that is not how manufacturers activate the laptops. It is such a big misconception for most people, especially on these forums. Believe what you want, but I know the key WILL work because the key IS NOT in use for his laptop.
https://linustechtips.com/topic/220329-operating-system/#findComment-3020317
I stopped reading your post at yes.
keys on the bottom of laptops will not work in a build.
end of story.
https://linustechtips.com/topic/220329-operating-system/#findComment-3020355
Scaryjam is correct with vista and 7 oem keys can be used to activate any disc retail or oem on any pc. With xp you would need to use a oem disc with an oem key.
Computer manufactures do not activate your copy of windows with the same key they put on the case. It's activate with a master product key.
https://linustechtips.com/topic/220329-operating-system/#findComment-3020863
You are mixing things now. Keys aren't CD/DVD bound. Or haven't been since XP.
I can't say about Win7 branded OEMs but my friend @GoodBytes could give view on that matter. Retail keys and non-branded OEMs can be reused. Either way, DO NOT ENTER key during installation. You can always activate license later and if it doesn't work you will have 30 days to get new license.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/220329-operating-system/#findComment-3026897
Reread what I said other then xp you can use oem disc or retail with an oem key.
I on avg activate around 10 windows 7 pc's  day and no matter the type of key I use the same disc.
https://linustechtips.com/topic/220329-operating-system/#findComment-3026950
