The best AIO is the X61/H220X, not entirely sure which one comes out on top.
Though the "best" watercooler would be a custom look with like triple 480s or some overkill monstrosity.
Edit:
The X61 beats the H220X, though it doesn't allow for further upgrades (like adding a GPU to the loop) unlike the H220X.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
Swiftech H320
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
The 'best' in terms of cooling would be any 360mm AIO cooler like the Swiftech H320 or the Thermaltake 3.0 Ultimate. If you need a good 240mm cooler then the Corsair H105 is good, its a thick version of the H100i.
Corsair 750D | Asus Crosshair V Formula-Z | FX 9590 | Kingston HyperX 16GB@1866MHz | MSI R9 290X Lightning | Seasonic 1050W Platinum | 2x WD 3TB Green HDD | Samsung 840 Pro 256GB SSD | Crucial 512GB SSD
Alphacool XT45 360mm | Alphacool Monsta 280mm | Silverstone AP121 | Silverstone AP141 | EK Supremacy Elite | EK ASUS C5F-Z | EK R9-290X Lightning | EK 3/8-1/2 Nickel | XSPC D5 Acrylic Tank | Primochill 3/8-1/2
the Thermaltake 3.0 can reach a higher Fan RPM  with a lower noise level then the H320. Does the mean the H320 is better?
and does the Thermaltalk 3.0 support expandability to the GPU like the H320 does?
I'm getting the Phantom 820 Case, Am I able to do a Push-Pull Config with these either of these two coolers??
If the fan rpm is higher with a lower noise level on the thermaltake then the thermaltake is better.
The thermaltake does not support expandability like the H320 does.
I'm unsure about push pull with the Phantom 820 as I don't know how much space is there in between the top of the case and the top of the motherboard you are going to use. Push/pull will only get you a few degrees cooler temps at most, so i wouldn't worry about it too much.
The expandability with the H320 is something I wouldn't recommend. Its still a great product but if you want to really expand the loop go with a custom loop.
If you want to go on the Corsair route, the H105 performs better than the H100i and features interchangeable coloured rings for the water-block.
Social Links: LTT Forum    Website    Instagram    Twitter    YouTube    LinkedIn    Steam
The Build
CPU Intel i7 4770k 4.4ghz Motherboard Asus Sabertooth Z87 RAM 34gb (4 x 8gb) Corsair Vengeance 1600mhz GPU Evga GTX780 Classified Case Lian Li O11 Dynamic Storage Samsung 840 256gb SSD PSU Corsair HX750 Display Achieva Shimian QH300-IPSMS 1600p Cooling Corsair H100i Keyboard Corsair K90 Mouse Corsair M65 Sound 3.1 Surround Sound Fans 2x Corsair SP120 PWM, 3x Corsair AF140 Q.E, and 1x Corsair AF120 Q.E.
Yea I looked into that. I think Im gunna go with the ThermalTake tho as it makes the most use of the Phantom 820 400mm top cooling space
I think this is the clearance spec u are looking for
Clearance CPU Cooler 153mm / 183mm without fan
Video 333mm
Cable Management 34mm
Just in case here is the link to the specs of the Phantom 820 - http://www.nzxt.com/product/detail/96-phantom-820-full-tower-case
and I will be using the ASRock Z97 EXTREME6 ATX LGA1150 - http://www.asrock.com/mb/Intel/Z97%20Extreme6/
Seeing the clearance I see the Gigabyte 970 G1 Just barely makes clearance on the video being 312mm (phew, hopefully those dimensions ring true and wont be an issue. I really want the G1 970 and I really like the look of the Phantom 820
Im not sure where they are taking there measurements from but im thinking of this for clearence. This space is important if you want to run a push/pull setup.
http://tinypic.com/r/2irswue/8
