Hi guys (and girls), I'm looking to build a compact rig (possibly in a fish tank, maybe mineral oil, maybe not) and I need a GPU shorter than 200mm. I've already seen the Asus GTX760 Mini, the MSI GTX760/R9270X, the new Sapphire R9285 ITX and the 750 Ti. Have you got any other suggestions? Thanks.
https://linustechtips.com/topic/219678-gpu-shorter-than-200mm/
R9 285 is a great option. However a 7770 will also do great if you want to save a bit of money.
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/219678-gpu-shorter-than-200mm/#findComment-3011159
I think those are pretty much all the ITX-GPUs out there that aren't low end. The R9 285 is definitely the best of them.
https://linustechtips.com/topic/219678-gpu-shorter-than-200mm/#findComment-3011196
  • 1 month later...
