northbridge, yes they got hot. my nforce 680i sli board has to have a fan to cool it :P
https://linustechtips.com/topic/219667-very-hot-heatsync/#findComment-3011007
From quickly reading some things on the internet about that board, it's not a really good one.
That being said, was that heatsink getting as hot in the past, or did it just start getting hot now?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/219667-very-hot-heatsync/#findComment-3011020
I recently replaced my motherboard with this one, so it's been like that ever since I noticed that. I don't know exactly how hot it is.
Is this bad or is there nothing to worry about ?
https://linustechtips.com/topic/219667-very-hot-heatsync/#findComment-3011029
I have been installing a few cheaper (sub $150) boards in customer builds, and have noticed the same things time to time...
Throw a fan on it/near it, if you don't have anywhere to mount it, use cable ties. If you have nowhere to plug it into the mobo, use an adapter.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/219667-very-hot-heatsync/#findComment-3011036
Well, generally motherboard heatsinks do get quite hot.
Maybe you could mount a fan to the side panel if there are mounting holes on the panel, and have it as an intake, to bring fresh air to your motherboard and other components..
https://linustechtips.com/topic/219667-very-hot-heatsync/#findComment-3011062
You can always attach a 40mm fan if you want but the northbridge is designed to run 90C 24/7. If the heatsink is warm that means it's doing its job.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/219667-very-hot-heatsync/#findComment-3011194
