So I just got my best friend who goes to UGA into CS:GO but his current PC just isn't doing it.
I have some (somewhat old) parts that I'd like to use if they could keep 60fps in CS:GO. Let me know and add on to my list of parts with the necessities. I want to give this to him as a birthday gift from his best bro, help make a dream come true!
CPU - AMD Phenom™ II X6 Black 1090t
RAM - 2g X 4 Corsair Dominator 1333hz
MOBO - Asus    Crosshair IV Formula
GPU - Asus   Radeon HD 5850
Cooler - Zalman CNPS9900 with blue led
I need a keyboard, mouse, monitor, windows 8.1, PSU, a harddrive, and a case. Love you guys!
https://linustechtips.com/topic/216911-help-for-budget-csgo-pc-machine/
What you have there will probably do a perfectly fine job as is
Keyboard: Corsair K70 with reds if he is only gaming and browns if he is gaming and typing.
Mouse: Corsair M65 or Razer Deathadder 2013 or Logitech G502 Proteus Core or Steelseries Sensai, whatever really.
Monitor: Any TN panel that has a reaonable response time and relatively low input lag.
PSU: Corsair RM650
HArddrive: WD Black 1TB and/or (Crucial MX100 128 or 256 GB)
Case: Fractal Design Define R4
"Have you tried turning it off and on again?"
What resolution are you playing on ?
What's your budget ?
Where are you buying your hardware ?
1080p
As efficient as possible. The least amount of money that can be spent without suffering performance gaps.
Online, I have amazon prime but if PCPARTPICKER shows another place as cheaper then I would follow.
sure, let me just go ahead and give him a PC with no mouse, keyboard, monitor, operating system, and case. Lmao
I meant you do not need to spend any money on CPU/GPU etc etc
