Project Alpha
I've been a pc enthusiast for just about a year or so. Building a gaming rig was only my goal at that time. But as time/months passed by, my love for PC grew. That is the time when i was hooked up to modding. This will  be my first ever PC Mod. Right now, i'm in a foreign land and it is hard for me to grab all tools and materials to do modding since im still not familiar in this country. Anyways, I will stop this nonsense and proceed with my build log.   :D
Below is the list of parts/hardwares to be used in this build. (This is my first time to build a Liquid Cooled PC and Im really excited :P) Some of the parts/hardware are to follow since this will be a Long Term Project.
Specs:
Case: Bitfenix Phenom ITX (Thanks Bitfenix for the free case) - ✓
CPU: I5 4670K will OC to 4.5 if possible - ✓
MoBo: Asus Z97i - Plus - ✓
RAM: Dominator Platinum 2400mhz - 2 x 8gb - ✓
GPU: GTX 760 - ✓ (waiting for GTX980 and block)
HDD: WD 500gb (planning to grab a NAS so no need for 1tb.) - ✓
SSD: to follow, still undecided
PSU: Corsair AX760 - ✓
Monitor: DELL - U2414H led - ✓
Keyboard: Razer DeathStalker -  ✓
Mouse: Razer Mouse (undecided)
MousePad: RAZER GOLIATHUS FRAGGED
Speaker: (undecided)
Water Cooling:
CPU Block: EK Supremacy CPU Block Nickel Plexy -  ✓
GPU Block: EK FC670/760 -  ✓
Rad: Black Ice GT Stealth 240 XFlow Rad -  ✓
Pump: EK DCP 4.0 Pump -  ✓
Reservoir: D65 x L170mm GLASS RES -  ✓
Fittings: Compression Fitting -  ✓
Fittings: 45 Degree Adapter -  ✓
Fittings: 90 Degree Adapter -  ✓
Flex Tube: Primochill Advanced LRT Tube
Coolant: Mayhem Pastel Green
MODS and Misc:
Fans 1: CM JetFlo 120 4pcs -  ✓
Fans 2: CM XtraFlo 12CM 2pcs  -  ✓
Fan Controller: Sentry LXE
GPU Back plate: Custom made -  ✓
Led Lights: OEM White-Blueish Led -  ✓
Sleeving: Nex-Gen Sleeves (White, Black, Green) -  ✓
1512787_10202127514721982_738812715_n.jp
https://linustechtips.com/topic/216891-project-alpha/
As much as I hate the Prodigy/Phenom, I can't wait to see what you do with it. Subbed. (If there are images already there, I can't see them because of my school's proxy.)
https://linustechtips.com/topic/216891-project-alpha/#findComment-2973361
ugh everything's gret but the 760 lets this system down allot :/
Specs
https://linustechtips.com/topic/216891-project-alpha/#findComment-2973379
As much as I hate the Prodigy, I can't wait to see what you do with it. Subbed. (If there are images already there, I can't see them because of my school's proxy.)
hahaha.. thanks man. i will be using Phenom. :P  i don't like the wobbly feet of prodigy. (no offence prodigy fans.) :wub:  ^_^
https://linustechtips.com/topic/216891-project-alpha/#findComment-2973380
hehe.. re-use bro. :) no choice. :(  need to replenish the wallet first. need also some fund for the modding tools and materials. so need to compromise a bit.  :P
more updates to be post later. be back in a while. :D
https://linustechtips.com/topic/216891-project-alpha/#findComment-2973400
Is your condo in Tokyo by any chance? Also SWEET MOTHER OF GOD, i like that acrylic platform!!
He's in Malaysia, the second to last picture you can see the Petronas Towers.
Looking to be an awesome build so far!
https://linustechtips.com/topic/216891-project-alpha/#findComment-2979035
Malaysia bro. :).. thanks.
Nice work man! Put the update in one post next time though please D:
thanks man. hehe. sorry. i was excited to update while order pictures are still uploading. hahaha. will do. thanks for the reminder. :D
yup. correct. im in KL. thanks man. :)
https://linustechtips.com/topic/216891-project-alpha/#findComment-2979095
another update.
psu shroud/pump concealer.
10710821_10203895911930807_7029527634383.
10690301_10203895913290841_7010447924300
sleeving time. :)
10653462_10203895913930857_3078858622402
i think the cables are too short. need to test it first. :P
10612844_10203895914810879_4174418759674
will update again this weekend. thanks for viewing guys. happy modding. :D
https://linustechtips.com/topic/216891-project-alpha/#findComment-2983012
hi guys, just a little update.
i was thinking of adding some acrylic for the design that needs bending. so did some experiment for the DIY bender.
here are some photos and sample bend.
10609621_10203905997222933_6918168336086
10387411_10203905997262934_3827902707773
1524911_10203905998062954_40704638948368
10653882_10203905998502965_6174102865305
1544346_10203905998462964_89903073378774
some parts of the bend got burnt coz i place it too close to the heat. for a first time, i can say it is a success, needs more practice though. have a great weekend guys. :)
https://linustechtips.com/topic/216891-project-alpha/#findComment-2994702
