For anyone who has ever overclocked this, what was your maximum settings? The most I can get without changing the voltage is 4.4GHz on a Hyper EVO with a Corsair SP fan.
The Grey Squirrel
CPU: i7-6700k @ 4.8GHz - CPU Cooler: Be Quiet! Dark Rock 3 - Motherboard: ASUS Z170-E - GPU:  ASUS GTX 1060 DUAL
Case: Inwin 303 - RAM: 4x8GB Corsair LPX Storage: 2x Samsung 850 EVO 500GB - PSU: EVGA SuperNOVA G2 550W
Mouse: Logitech G502 Wired / Bungee Keyboard: Corsair Strafe Cherry MX Red Headphone: Sony MDR- 1R
Microphone:  Blue Yeti - Webcam: Logitech C920 - Monitors: 3x Dell S2415H
https://linustechtips.com/topic/216645-i5-4670k-overclocking-help/
Without changing the voltage? The default setting is auto and not recommended for oc'ing.
Have you tried following this guide?
it depends on the CPU. each silicon chip will overclock slightly different.
I run mine at 4.5ghz, but I;ve gotten it to 4.9 with slight instabilities
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
Turns out I was not giving it enough voltage (1.23 instead of 1.3, my mistake). I'm testing it right now at 1.3/4.5GHz
The Grey Squirrel
1.3V is the max voltage you should be using with that CPU. You don't need to crank it up to that level if you can run clocks you like without it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
x47 core x43 uncore(cache)
1.23v core
1.20v cache
1.81v VCCIN (also called VRIN)
+.05v offsets
LLC=5
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
