@lewisj488
The system is good enough for moderate gaming and a little streaming and rendering...
It's a bit underpowered on the GPU side but it should hold for a few years...
Did you get the parts new or used?
https://linustechtips.com/topic/215827-i-got-some-parts/#findComment-2956149
The CPU is very good also they are 3.4GHz stock and 3.8GHz Turbo.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/215827-i-got-some-parts/#findComment-2956156
The cpu is more powerful than that GPU xD
also budget?
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/215827-i-got-some-parts/#findComment-2956166
@lewisj488
I got them used, around 6 months of use
https://linustechtips.com/topic/215827-i-got-some-parts/#findComment-2956170
They should last you for quite some time... I'd suggest getting a better GPU for that though... 1 or 2 tiers above the 750Ti will serve you well...
The mobo should be a PCIe 2.0 so I'm not sure how performance would end up...
https://linustechtips.com/topic/215827-i-got-some-parts/#findComment-2956187
https://linustechtips.com/topic/215827-i-got-some-parts/#findComment-2956282
Could I use a Gtx 750 ti and a Samsung SSD840 Pro SATA III be compatible with my build ?
yes but for the GPU i'd strongly suggest looking at AMD product because at that price range of the 750ti you can get a radeon R9 270 or R9 270X for example that outperforms the 750ti by a very noticeable margin:
R9 270 vs GTX 750ti
http://www.anandtech.com/bench/product/1080?vs=1130
If you buy used you could also find a bargain on an HD7870 which is pretty much the same GPU
HD7870 vs GTX 750ti
http://www.anandtech.com/bench/product/1034?vs=1130
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/215827-i-got-some-parts/#findComment-2956732
