Question about my Build
Go to solution Solved by mgsstar,
Hi
I would like to know if the cooler master 212 EVO will fit inside the Aerocool DS 200
Case: http://www.pccasegear.com/index.php?main_page=product_info&products_id=28910
Cooler: http://www.pccasegear.com/index.php?main_page=product_info&products_id=18670
On the manufacturer's website, it says that it supports up to 170m (think its supposed to be 170mm not 170m) and the Evo cooler is 158.5mm so it will be able to fit in that case.
Sources:http://www.coolermaster.com/uploadfile/upload/images/cooling/Hyper-212-EVO-measurement-600.jpg
http://www.aerocool.com.tw/index.php/chassis/ds/ds-200/78-case/ds/1264-ds-200-blue-edition-specs
Hi
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/215665-question-about-my-build/#findComment-2954053
