whenever i try to play, i get the error shown below. I had this error on 1.7.10 AND 1.8. I've tried reinstalling MC and that didn't help
Error:
[10:35:35] [Client thread/INFO]: Setting user: ___________
[10:35:35] [Client thread/INFO]: (Session ID is token:d0268af931e54a0ea0d43278b1fdabf4:a88a5af4c1c649ce953a2b0def885202)
[10:35:38] [Client thread/INFO]: LWJGL Version: 2.9.1
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ffa68a60158, pid=4852, tid=4924
# JRE version: Java SE Runtime Environment (7.0_67-b01) (build 1.7.0_67-b01)
# Java VM: Java HotSpot 64-Bit Server VM (24.65-b04 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C  [OPENGL32.dll+0x40158]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# C:\Users\__________\AppData\Roaming\.minecraft\hs_err_pid4852.log
# If you would like to submit a bug report, please visit:
#   http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
any help?
Linus once unboxed a Toblerone
https://linustechtips.com/topic/214734-minecraft-wont-start/
Have you changed anything with the RAM allocation?
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938606
not since i reinstalled. It only has 1GB allocated to it.
since i suck at reading crash reports... are you running forge or any mods?
not anymore, but i did have crashes then too.
Reinstall java and see if your drivers are up to date.
already did. I even upgraded to 64bit java
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938619
make sure everything is up to date, what version of mc? and what java?
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938661
Um sir remove your name from that log O.o
Open %appdata% .Minecraft and delete everything execpt:
/saves
/Resourcepacks
/options.txt
/optionsof.txt
/Servers.dat
This will force the game to retrieve new libraries. OpenGl Error also could refer to wrong vgadrivers.
Bye LTT. That was an interesting journey on this board. At least here you see how not to do it. I'll go shaking my head about this place.
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938674
I'm running the latest everything. 340.52 GPU Drivers, MC1.8, and 64bit Java 7.
/saves
/Resourcepacks
/options.txt
/optionsof.txt
/Servers.dat
Good point...
And i already backed up my saves and texturepacks and deleted everything else. Even the Minecraft.exe
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938712
-snip-
oi :( maybe check the mc forums, i was kinda hoping this would be a simple fix, sorry if i let ya down.
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938733
it's fine. :) i'm glad you tried
You are running it on PC, that's why. Go get a console, a mountain dew, a bag of domino's, your mom's credit card for texture packs and skins then you are in business!
Console's not bad, but it's left in the dust on updates and texturepacks cost money. I also can't stand playing with a controller on MC. also, shaders :3
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938769
Good point...
Have you tried from java 8? http://www.oracle.com/technetwork/java/javase/downloads/jre8-downloads-2133155.html Wild guess is to downgrade to the previous vga drivers.
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938777
Maybe upgrading to Java 8 is what i need. I'll try it and get back to you
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938813
cant tell if troll or actually thinks consoles are better....
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938825
Complete troll, I'm a proud member of the on and only PCMR.
good, you passed the test.
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938851
[11:06:23] [Client thread/INFO]: Setting user: __________
[11:06:23] [Client thread/INFO]: (Session ID is token:d0268af931e54a0ea0d43278b1fdabf4:a88a5af4c1c649ce953a2b0def885202)
[11:06:25] [Client thread/INFO]: LWJGL Version: 2.9.1
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ffa68a60158, pid=2168, tid=2944
# JRE version: Java SE Runtime Environment (8.0_20-b26) (build 1.8.0_20-b26)
# Java VM: Java HotSpot 64-Bit Server VM (25.20-b23 mixed mode windows-amd64 compressed oops)
# C:\Users\_________\AppData\Roaming\.minecraft\hs_err_pid2168.log
Java HotSpot 64-Bit Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938876
how would i go about doing that with GeForce Experience?
You go to System -> Programms and uninstall if from there. Or into devicemanager and click uninstall drivers. Then restart your pc and download them from your vendors site.
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2938975
I'll try it, but not quite yet. I'll see if there are other options. Drivers are simple, yet a pain in the butt in my opinion. Thanks for the help :)
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2939004
Make sure your have the latest version/s of Java. 64 Bit AND 32 Bit. Some applications (like Google Chrome) use 32 Bit Java. Also, uninstall ALL previous versions of Java (32 Bit and 64 Bit) because they can also interfere with your game. You can also try setting a certain amount of RAM to Minecraft by opening the launcher,  going to Edit Profile (bottom left) enabling JVM Arguments and changing -Xmx1G to a -Xmx2G or -Xmx4G if need be. You don't need any more than -Xmx3G for modded Minecraft and the recommended vanilla amount is -Xmx1G anyways.
If all else fails, make a backup or your saves folder under %appdata% /.minecraft/saves and delete the comeplete .minecraft folder and launcher and redownload everything. Then put your saved worlds back in the saves folder.
If you are using a laptop, you may have Switchable Graphics. Right click on your desktop and select Configure Switchable Graphics (AMD) or NVIDIA Control Panel (NVIDIA Obviously...) and change the currently used graphics processor to use the High Performance preset.
And if all else fails, you can update all of your drivers OR get a clean install of Windows.
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2972661
I'm running 64-Bit chrome, but i will install 32-bit Java 8 and get back to you. I'm already running 64-Bit Java 8. I'll also try different amounts of RAM. I wanted to leave it vanilla as a controlled test.
I've already backed up all my saves and uninstalled it. I deleted the .minecraft folder and the .exe and did a full re-install. didn't work.
I'm on a desktop. I'm pretty sure core 2 quads don't have iGPUs, so i don't believe that's an issue.
I'm thinking it might be an issue with cloning my HDD to my SSD. i'll do a clean install when wind.9 comes out. I have games that still work fine, so i'm not worried.
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2973771
32-Bit Java and 4G RAM didn't help. i even tried older Java versions.
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2973871
Maybe Microsoft already released a patch to make it better. HAHAHAHA! No, they just make everything worse.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2973902
I'm more worried about Notch leaving than microsoft owning the company. Also, if you're just going to be snide, there are other threads for you.
https://linustechtips.com/topic/214734-minecraft-wont-start/#findComment-2973915
