Installing cooler without backplate
Go to solution Solved by RevoltTrain,
You may be able to find a backplate on Craigslist or Ebay.
So my buddy is taking my h60 off my hands and wants me to install if for him.  He has long since lost his amd backplate for his mobo.
Exactly how essential to the installation is having the amd backplate?
could it be (semi)safely ghetto rigged?
Is there a place to get an extra backplate from?
Thanks m8s
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/214316-installing-cooler-without-backplate/
Some Intel 775 boards didn't require a backplate because the holes are small enough for an aftermarket cooler. Mine is one of those.
So just try it and see?
I'd rather just get an extra backplate but i really have no idea where to find an extra
I'd say that you should try to search around on the internet for a backplate anyway, it helps to strengthen & keep the coolers retention quite firm onto the cpu socket. @Vizzion
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
Doubt that motherboards nowadays have small holes. Especially Intel. They enlarged the holes so they can fit a stupid stock cooler.
You could have issues with making tight enough contact between cooler and CPU. With AIO there isn't problem of cooler being too heavy.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Found the parts I need on ebay finally. Thanks peeps.
