os on ssd and programs files on Hdd? help?
Solved by GoodBytes,
If you want your program seperated from the SSD, you don't need move "Program Files" folder... In fact don't move it, because you'll break Windows built-in programs.
When you install a program, you can pick the path you want to install the program. So in your case, it should be D:\<Program Name> or how ever you want.. like D:\Software\Best Software\Bestest of Best Software\<Program Name>. It doesn't mater. :)
For example:
Let's say you want want to install "anch2797's AWESOME SOFTWARE OF D00000M!!!!!"
You'll get to this screen, where you change the path from C:\Program Files (x86)\anch2797's AWESOME SOFTWARE, to D:\anch2797's AWESOME SOFTWARE, as demonstrated bellow:
That is all you have to do!
(yes, I just made a setup, just for you :) )
