I'm gonna be 18 soon ( 23 oct.) , and my parents asked what should they get me . Naturally , i wanted some pc gear , but what should i get ??
The Budget is unknown but i'd say mid-highend stuff
EDIT : Current rig ( aka what i'm typing on )
PCPartPicker part list: http://pcpartpicker.com/p/xGfZzy
CPU: Intel Core i5-2310 2.9GHz Quad-Core Processor
CPU Cooler: Noctua NH-L9i 57.5 CFM CPU Cooler
Motherboard: OEM ASUS h61 mobo
Memory: Corsair XMS3 8GB (2 x 4GB) DDR3-1333 Memory
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI GeForce GTX 760 2GB TWIN FROZR Video Card
Case: Corsair C70 Arctic White (White/Black) ATX Mid Tower Case
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply
Monitor : 2x 1080p ( 1 VA & 1 IPS ) monitors
Getting a new cpu and mobo would not really increase the fps in games much since the i5 doesnt really bottleneck the 760 unless playing Planetside 2
900 series nvidia is just around the corner so a 780 ti wouldn't be witty.
Was thinking about one of those eBay korean 1440p monitors but i'm really afraid it will be DOA or missing some pixels. Ideas ?
Bare in mind i live in Romania , where prices are about 1$---->1€+10-20% so yhea , no 5930k & x99 , gtx titan stuff :(
Edited by Si3Rra_7
https://linustechtips.com/topic/213654-18th-birthday-help/
290 and 3570k :DDDD
Try getting Ivy Bridge (3rd gen) CPU.
And don't listen to that guy^, a R9 290 is overkill for 1080p.
lol ? ivy ? should i look in the museum for that ? Also failed to mention im a huge nvidia fan :D ( would reccomend 750ti over anything better value from amd :D )
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2920047
Ivy Bridge is the codename for the 3rd gen CPU's. A quick Google search can do that.
Okay so :D get the 750Ti :D I can't help fanboys. If you want the best for value, then AMD is the choice. Romanian prices are high? Not my fault. 750Ti doesn't sound too bad. :D
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2920111
LEL. I got a 780 and I play on 720p.
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2920142
dude i know what ivy bridge is , also you didnt even look at my post, i already have a 760. and i told you about the prices just to be sure no one recommends stuff thats really expensive. not good LTT forum etiquette there sir !
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2920453
How would I know you already have the GTX 760?
I'd still get 3rd gen or 4th gen CPU.
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2920506
happy birthday soon to be adult guy
Thanks, and to you too:)
Now I would definitely recommend upgrading to a newer platform, whether it's just a CPU or going straight to Haswell.
If you don't feel like it, then spring for 1440p, I never even looked back after getting my Korean panel... So sharp... So many pixels...
I'm that guy with the GPD Win.
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2920678
OH
Sorry bout that, I didn't find a single word on "upgrade", I thought you were getting a new PC. And by current I thought you meant your current plan. >.<
Yhea, might have been a bit vague since english isn't my first language and i'm writing this at 5:27 AM with my right hand which is in a cast :/
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2920784
No problem, just a little misunderstanding.
Ask your parents for a tech store gift card, then you can wait for the 900 series and get an even better GPU. Can you try selling your GTX 760? Then you might be able to upgrade to a new CPU and mobo.
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2920801
IMHO, you're not officially an adult until you're out of your teens and into twenties. ;)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2921007
Cash (or prepaid VISA card) is always king in my book.
Or a VISA Debit card (acts like a credit card but uses you're own money instead, prevents getting in debt). ;)
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2921120
I know you said your cpu doesn't really bottleneck you, but that's what I'd go for. I'd try for a 4690k and a decent motherboard (in the $120-$160 range). I'd do this because I prefer a strong foundation before getting the flashy graphics card. Sure a 290 will increase your FPS right now, but the 760 is already a great video card. The 4690k would last you years, but a 1440 monitor might be crap in just two (seriously, 4K is getting damn cheap!). Next I'd get the graphics card and THEN the monitor. By then you could get a 4k monitor because the price would be cheap enough. And you would want to get the graphics card first so you can actually enjoy the gaming experience on it. And who knows, maybe you'll want the GTX 970.
i7 4770k @ 4.6ghz | Gigabyte GA-Z87X-UD3H | G.SKILL Ripjaws X Series 16GB | Sapphire Vapor-X 7970 Ghz | Fractal Design Arc Midi R2
Samsung 840 EVO 250GB SSD | Toshiba 7200rpm 3TB | Seasonic 660W Platinum | Corsair H100i
Logitech G400s | Ducky Shine III Cherry MX Brown
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2921159
That's what I meant by prepaid. Can't prepay a credit card...to my knowledge.
I edited my post above. Have a look ^.
https://linustechtips.com/topic/213654-18th-birthday-help/#findComment-2921182
