I need help chossing the right GPU for my system.
Go to solution Solved by Igor Perrotta,
it gave me the same to me too. ok so it is decided I'm going to put and extra stick of ram swap my father's power supply (Cheaper than buying one) and buy a r7 250 hopefully I would get about 30 at 720p normal to high setting in this thing!
Again just check the voltage in your psu do some searching about it. DONT TAKE RISKS IF THAT SHIT BLOW you will lose everything. i think it wont blow but its better be cautious . 720p gaming in low or medium depending on the game. If you want to play with me on steam ADD ME: Perrottzz  please click in the solved button to close this topic. cya
This is my first post so I'm going to start saying hello to all you reading this, ok now let's get into it.
My system is not the best in the world by any chance, as a matter of fact I think is pretty bad, unfortunately this is what I'm stuck with:
My PC.html
Now, I'm going to upgrade my ram to 4GB.
And this is the GPU I had in mind:
http://www.evga.com/Products/Product.aspx?pn=01G-P4-3743-KR
I try to learn as much as I could about this things for the last week or so but I want to be sure.
If you need more information let me know.
Thank you in advance.
Could you copy your build into the thread?
whats your budget for upgrade?
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
Welcome!! That is a good choice, or the GTX 750 for a little more, but wait a little bit for other opinions
And enjoy your stay at the Linus Tech Tips forum rated 10/5 hehe :P
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
Well, AMD nowadays tends to have better performing gpus in a lower range of budgets. Have that in mind.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
Personally, I think your build is underpowered, so I would stick to something low-tier as your GPU will rarely be your bottleneck, so the Radeon r7 240 seems like it would be okay for this build.
My budget is about $100
here is my system:
CPU-Z TXT Report
Binaries
CPU-Z version            1.70.0.x32
Processors
Number of processors        1
Number of threads        2
APICs
Processor 0
    -- Core 0
        -- Thread 0    0
    -- Core 1
        -- Thread 0    1
Timers
    ACPI timer        3.580 MHz
    HPET timer        25.000 MHz
    Perf timer        2.747 MHz
    Sys timer        1.000 KHz
Processors Information
Processor 1            ID = 0
    Number of cores        2 (max 2)
    Number of threads    2 (max 2)
    Name            AMD Athlon II X2 240
    Codename        Regor
    Specification        AMD Athlon X2 240 Processor
    Package         Socket AM3 (938)
    CPUID            F.6.2
    Extended CPUID        10.6
    Brand ID        13
    Core Stepping        DA-C2
    Technology        45 nm
    TDP Limit        62 Watts
    Core Speed        2812.9 MHz
    Multiplier x Bus Speed    14.0 x 200.9 MHz
    HT Link speed        1004.6 MHz
    Stock frequency        2800 MHz
    Instructions sets    MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
    L1 Data cache        2 x 64 KBytes, 2-way set associative, 64-byte line size
    L1 Instruction cache    2 x 64 KBytes, 2-way set associative, 64-byte line size
    L2 cache        2 x 1024 KBytes, 16-way set associative, 64-byte line size
    FID/VID Control        yes
    FID range        4.0x - 14.0x
    Max VID            1.425 V
    # of P-States        4
    P-State            FID 0xC - VID 0x0A - IDD 23 (14.00x - 1.425 V)
    P-State            FID 0x5 - VID 0x12 - IDD 20 (10.50x - 1.325 V)
    P-State            FID 0x0 - VID 0x1A - IDD 19 (8.00x - 1.225 V)
    P-State            FID 0x100 - VID 0x22 - IDD 7 (4.00x - 1.125 V)
    Package Type        0x1
    Model            40
    String 1        0x3
    String 2        0x6
    Page            0x0
    CmpCap            2
    ApicIdCoreSize        4
    TDC Limit        46 Amps
    Boosted P-States    0
    Max non-turbo ratio    14.00x
    Max turbo ratio        14.00x
    Max CPU COF        28
    Core Performance Boost    no
    P-State            0, FID 0xC - VID 0x0A (14.00x - 1.425 V)
    P-State            1, FID 0x5 - VID 0x12 (10.50x - 1.325 V)
    P-State            2, FID 0x0 - VID 0x1A (8.00x - 1.225 V)
    P-State            3, FID 0x100 - VID 0x26 (4.00x - 1.075 V)
    Attached device        PCI device at bus 0, device 24, function 0
    Attached device        PCI device at bus 0, device 24, function 1
    Attached device        PCI device at bus 0, device 24, function 2
    Attached device        PCI device at bus 0, device 24, function 3
    Attached device        PCI device at bus 0, device 24, function 4
    TSC            2813.0 MHz
    PERFEVT            2813.0 MHz
Thread dumps
CPU Thread 0
    APIC ID            0
    Topology        Processor ID 0, Core ID 0, Thread ID 0
    Type            0200400Bh
    Max CPUID level        00000005h
    Max CPUID ext. level    8000001Bh
    Cache descriptor    Level 1, I, 64 KB, 1 thread(s)
    Cache descriptor    Level 1, D, 64 KB, 1 thread(s)
    Cache descriptor    Level 2, U, 1 MB, 1 thread(s)
    CPUID
    0x00000000        0x00000005    0x68747541    0x444D4163    0x69746E65
    0x00000001        0x00100F62    0x00020800    0x00802009    0x178BFBFF
    0x00000002        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000003        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000004        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000005        0x00000040    0x00000040    0x00000003    0x00000000
    0x80000000        0x8000001B    0x68747541    0x444D4163    0x69746E65
    0x80000001        0x00100F62    0x10001A86    0x000037FF    0xEFD3FBFF
    0x80000002        0x20444D41    0x6C687441    0x74286E6F    0x5820296D
    0x80000003        0x34322032    0x72502030    0x7365636F    0x00726F73
    0x80000004        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000005        0xFF30FF10    0xFF30FF20    0x40020140    0x40020140
    0x80000006        0x20800000    0x42004200    0x04008140    0x00000000
    0x80000007        0x00000000    0x00000000    0x00000000    0x000001F9
    0x80000008        0x00003030    0x00000000    0x00002001    0x00000000
    0x80000009        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000A        0x00000001    0x00000040    0x00000000    0x0000000F
    0x8000000B        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000C        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000D        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000E        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000F        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000010        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000011        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000012        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000013        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000014        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000015        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000016        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000017        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000018        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000019        0xF0300000    0x60100000    0x00000000    0x00000000
    0x8000001A        0x00000003    0x00000000    0x00000000    0x00000000
    0x8000001B        0x0000001F    0x00000000    0x00000000    0x00000000
    MSR 0x0000001B        0x00000000    0xFEE00900
    MSR 0xC0010114        0x00000000    0x00000000
    MSR 0xC0010061        0x00000000    0x00000030
    MSR 0xC0010062        0x00000000    0x00000000
    MSR 0xC0010063        0x00000000    0x00000000
    MSR 0xC0010064        0x800001E1    0x1400140C
    MSR 0xC0010065        0x800001CC    0x24002405
    MSR 0xC0010066        0x800001BD    0x34003400
    MSR 0xC0010067        0x8000014A    0x44004440
    MSR 0xC0010068        0x00000000    0x00000000
    MSR 0xC0010071        0x30B80053    0x1400140C
    MSR 0xC0010015        0x00000000    0x01000011
    MSR 0xC001001F        0x00404000    0x00000008
    MSR 0xC0010058        0x00000000    0xF0000001
    MSR 0xC0010070        0x00000000    0x1400140C
CPU Thread 1
    APIC ID            1
    Topology        Processor ID 0, Core ID 1, Thread ID 0
    Type            0200400Bh
    CPUID
    0x00000001        0x00100F62    0x01020800    0x00802009    0x178BFBFF
    MSR 0x0000001B        0x00000000    0xFEE00800
Chipset
Northbridge            NVIDIA MCP61 rev. A3
Southbridge            NVIDIA MCP61 rev. A2
Memory Type            DDR2
Memory Size            2 GBytes
Channels            Single
Memory Frequency        334.9 MHz (3:5)
CAS# latency (CL)        5.0
RAS# to CAS# delay (tRCD)    5
RAS# Precharge (tRP)        5
Cycle Time (tRAS)        15
Bank Cycle Time (tRC)        20
Command Rate (CR)        1T
Uncore Frequency        1607.4 MHz
Memory SPD
DIMM #                1
    SMBus address        0x50
    Memory type        DDR2
    Module format        Regular UDIMM
    Manufacturer (ID)    Avant Technology (7F7F7F7F7FF700000000)
    Size            2048 MBytes
    Max bandwidth        PC2-5300 (333 MHz)
    Part number
    Number of banks        2
    Data width        64 bits
    Correction        None
    Nominal Voltage        1.80 Volts
    EPP            no
    XMP            no
    AMP            no
JEDEC timings table        CL-tRCD-tRP-tRAS-tRC @ frequency
    JEDEC #1        3.0-3-3-9-12 @ 200 MHz
    JEDEC #2        4.0-4-4-12-16 @ 266 MHz
    JEDEC #3        5.0-5-5-15-20 @ 333 MHz
DIMM #                1
SPD registers
        00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
    00    80 08 08 0E 0A 61 40 00 05 30 45 00 82 08 00 00
    10    0C 08 38 01 02 00 03 3D 45 50 45 3C 1E 3C 2D 01
    20    20 27 10 17 3C 1E 1E 00 06 3C 7F 80 18 22 00 00
    30    00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 ED
    40    7F 7F 7F 7F 7F F7 00 00 00 00 00 46 36 34 35 36
    50    55 36 31 45 35 36 36 37 46 00 00 00 00 00 00 00
    60    00 00 00 54 46 38 33 35 41 00 00 00 00 00 00 00
    70    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    80    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    90    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    A0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    B0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    C0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    D0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    E0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    F0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Monitoring
Mainboard Model        M61PMV (0x000001A7 - 0x005364C0)
LPCIO
LPCIO Vendor        ITE
LPCIO Model        IT8716
LPCIO Vendor ID        0x90
LPCIO Chip ID        0x8716
LPCIO Revision ID    0x3
Config Mode I/O address    0x2E
Config Mode LDN        0x4
Config Mode registers
    00    00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
    10    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    20    87 16 03 11 00 00 01 00 00 00 80 00 1F 00 00 00
    30    01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    40    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    50    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    60    02 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    70    00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space        LPC, base address = 0x0290
Hardware Monitors
Hardware monitor    ITE IT87
    Voltage 0    1.44 Volts [0x5A] (CPU VCORE)
    Voltage 1    1.87 Volts [0x75] (VIN1)
    Voltage 2    3.42 Volts [0xD6] (+3.3V)
    Voltage 3    5.08 Volts [0xBD] (+5V)
    Voltage 4    12.10 Volts [0xBD] (+12V)
    Voltage 7    4.92 Volts [0xB7] (+5V VCCH)
    Voltage 8    3.22 Volts [0xC9] (VBAT)
    Temperature 0    34°C (93°F) [0x22] (TMPIN0)
    Temperature 1    34°C (93°F) [0x22] (TMPIN1)
    Temperature 2    22°C (71°F) [0x16] (TMPIN2)
    Fan 0        3027 RPM [0xDF] (FANIN0)
    Fan 2        3689 RPM [0xB7] (FANIN2)
    Fan PWM 0    50 pc [0x40] (FANPWM0)
    Fan PWM 1    50 pc [0x40] (FANPWM1)
    Fan PWM 2    50 pc [0x40] (FANPWM2)
    00    13 00 FF 00 FF FF 00 00 00 80 3F 09 07 E0 FF B6
    10    EF FF FF 70 50 40 40 40 00 FF 00 FF FF FF FF FF
    20    5A 75 D6 BD BD 04 06 B7 C9 22 22 16 C8 D2 D2 D2
    30    FF FF FF FF FF FD FF F7 FF FF FF FF FF FF FF FF
    40    7E 7F 7E 7F 7E 7F 5F 74 2D 40 AB 22 FF FF FF FF
    50    FF 31 7E 7F 7F 50 FC 5D 90 5D 00 12 E0 00 00 00
    60    7F 7F 7F 00 00 3F FF FF 7F 7F 7F 00 00 3F FF FF
    70    7F 7F 7F 00 00 3F FF FF FF FF FF FF FF FF FF FF
    80    00 00 00 00 FF FF FF FF 00 00 FF CA 02 00 99 99
    90    7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF
    A0    00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
    B0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    C0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    D0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    E0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    F0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor    ACPI
    Temperature 0    40°C (103°F) [0xC3C] (THRM)
DMI
DMI BIOS
    vendor            Phoenix Technologies LTD
    version            P05
    date            02/23/2009
    ROM size        1024 KB
DMI System Information
    manufacturer        FOXCONN
    product            M61PMV
    version            FAB 1.0
    serial            unknown
    UUID            {5140B9E0-E91D-116B-E28A-00226871CA98}
    SKU            unknown
    family            unknown
DMI Baseboard
    vendor            FOXCONN
    model            M61PMV
    revision        FAB 1.0
    serial            UY30921094834
DMI System Enclosure
    chassis type        Desktop
    chassis serial        Unknow
DMI Processor
    manufacturer        AMD
    model            AMD Athlon X2 240 Processor
    FSB speed        200.0 MHz
DMI Memory Controller
    correction        64-bit ECC
    Max module size        2048 MBytes
DMI Memory Module
    designation        A0
    size            2048 MBytes (double bank)
DMI Memory Module
    designation        A1
DMI Port Connector
    designation        PRIMARY IDE (internal)
    connector        On Board IDE
DMI Port Connector
    designation        SATA1 (internal)
DMI Port Connector
    designation        SATA2 (internal)
DMI Port Connector
    designation        SATA3 (internal)
DMI Port Connector
    designation        SATA4 (internal)
DMI Port Connector
    designation        FDD (internal)
    port type        8251 FIFO Compatible
    connector        On Board Floppy
DMI Port Connector
    designation        IR (internal)
    port type        Serial Port 16450
    connector        9 Pin Dual Inline (pin 10 cut)
    connector        DB-9 male
DMI Port Connector
    designation        COM1 (internal)
    connector        DB-9 male
DMI Port Connector
    designation        LPT1 (internal)
    port type        Parallel Port ECP/EPP
    connector        DB-25 female
DMI Port Connector
    designation        Keyboard (internal)
    port type        Keyboard Port
    connector        PS/2
    connector        PS/2
DMI Port Connector
    designation        PS/2 Mouse (internal)
    port type        Mouse Port
    connector        PS/2
    connector        PS/2
DMI Port Connector
    designation        USB0 (external)
    port type        USB
DMI Port Connector
    designation        USB1 (external)
    port type        USB
DMI Port Connector
    designation        USB2 (external)
    port type        USB
DMI Port Connector
    designation        USB3 (external)
    port type        USB
DMI Port Connector
    designation        USB4 (external)
    port type        USB
DMI Port Connector
    designation        USB5 (external)
    port type        USB
DMI Port Connector
    designation        USB6 (external)
    port type        USB
DMI Port Connector
    designation        USB7 (external)
    port type        USB
DMI Port Connector
    designation        VIDEO (external)
    port type        Video Port
    connector        DB-15 female
DMI Port Connector
    designation        AUDIO (external)
    port type        Audio Port
DMI Port Connector
    designation        ETHERNET (external)
    port type        Network Port
    connector        RJ-45
DMI Extension Slot
    designation        PCI0
    type            PCI
    width            32 bits
    populated        no
DMI Extension Slot
    designation        PCI1
    type            PCI
    width            32 bits
    populated        no
DMI Extension Slot
    designation        PCIE
    type            A5
DMI Extension Slot
    designation        PCIE
    type            A5
DMI Physical Memory Array
    location        Motherboard
    usage            System Memory
    correction        None
    max capacity        4096 MBytes
    max# of devices        2
DMI Memory Device
    designation        A0
    format            DIMM
    type            unknown
    total width        64 bits
    data width        64 bits
    size            2048 MBytes
DMI Memory Device
    designation        A1
    format            DIMM
    type            unknown
    total width        64 bits
    data width        64 bits
Storage
Drive    0
    Device Path        \\?\scsi#disk&ven_fujitsu&prod_mhz2080bh_g1#4&394ef74&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
    Type            Fixed
    Name            FUJITSU MHZ2080BH G1
    Capacity        74.5 GB
    SMART Support        Yes
Drive    1
    Device Path        \\?\scsi#disk&ven_wdc_wd32&prod_00aajs-00l7a#4&394ef74&0&010100#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
    Type            Fixed
    Name            WDC WD32 00AAJS-00L7A
    Capacity        298.1 GB
    SMART Support        Yes
USB Devices
Graphics
Number of adapters        1
Graphic APIs
API                NVIDIA I/O
API                NVIDIA NVAPI
Display Adapters
Display adapter 0
    Name            NVIDIA GeForce 6150SE nForce 430
    Board Manufacturer    0x105B (0x0EFE)
    Revision        A2
    Memory size        128 MB
    PCI device        bus 0 (0x0), device 13 (0xD), function 0 (0x0)
    Vendor ID        0x10DE (0x105B)
    Model ID        0x03D0 (0x0EFE)
    Performance Level    0
        Core clock    425.0 MHz
        Memory clock    666.0 MHz
Win32_VideoController        AdapterRAM = 0x8000000 (134217728)
Win32_VideoController        DriverVersion = 9.18.13.783
Win32_VideoController        DriverDate = 01/31/2013
Software
Windows Version            Microsoft Windows 7 (6.1) Ultimate Edition 32-bit  Service Pack 1 (Build 7601)
DirectX Version            11.0
-snip-
I'd say a good option is a r7 240 and upgrading some ram.
Thanks for the suggestion Vawqer. I know is and old machine I'm concern about the PSU thought I have couple of wires let over but I don't if it would work
Would it run some games with a extra stick of ram and the r7 240 I'm not even going to do 1080p but I'm hopping for 720p decent fps and medium to high setting. am I asking too much from this pc?
I would suggest the R7 250 which comes in at around 100$.
The 240 and 740 is too low-end, while the 250 is a big step from the 240.
I would also suggest upgrading your RAM to 4GB if possible. This can cost around 40$, or if you have enough RAM slots on your mobo, you could just add another 2GB of RAM for barely 25$.
oh well yeah whats your PSU??
A R7 250 its a good one and like everyone said a ram upgrade to 4gb.
I would suggest a 350w power supply a good on.(but i think its a litte too much)
I would spent the extra $60 bux for this video card, it needs less power than the 740 and is better. http://www.amazon.com/EVGA-Superclock-Dual-Link-Graphics-02G-P4-3753-KR/dp/B00IDG3IDO/ref=sr_1_1?ie=UTF8&qid=1410483183&sr=8-1&keywords=gtx750ti its a GTX750ti, its small and good for the price. But before you get any GPU, make sure you power-supply can handle it. GOOD LUCK!
welcome to the forums young padawon.
I think it wont work as well. his processor is not that strong
Ok guys I don't know much about PSU's so I take a photo of mind here it is
I can see its a 230w power supply and its not a good one i would suggest a upgrade. you are going to be upgrading a gpu ram psu. why dont buy a new pc? if money is a problem google $500 gaming pc its cheap and will guarantee low to medium 1080p on games
Like I said at the beginning I'm stuck with this, So this PSU won't run a r7 240 or something or I would have to attach a  hamster wheel on the side for extra 12V power?
Like I said at the begging I'm stuck with this, So this PSU won't run a r7 240 or something or I would have to attach a  hamster wheel on the side for extra 12V power?
I dont know if this power supply really delivers the 230w i dont want your pc to explode. but for a 240 i think it will hold ok.  but a 250 no
But the hamster wheel is a good idea
Lol I know right, I have to be sure here because I'm in Costa Rica and I will buy on amazon and get it sent to me down so I really want this to work
Im from brazil HERE EVERYTHING IS EXPENSIVE so i have to be very careful. and i dont want to fuck your pc up
Posted a photo of mine up there some where I would like to hear your opinion on all this Deletive
Video Card: Asus Radeon R7 240 2GB Video Card  ($54.99 @ Micro Center)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($19.99 @ Newegg)
Total: $74.98
Generated by PCPartPicker 2014-09-11 21:19 EDT-0400
try something like this.
Thanks! I trust you bro so r7 240 is a little bit cheaper than the gt 740 put performs equal or better, both work with my PSU or only the r7 240
