The latest nVidia driver + geforce experience really messed with my OS.
I'm using Win7 x64 and running a GTX460 and after installing the above I had experienced (almost right away in bad driver terms, a couple of hours
after the update) hard hags, system lag and an overall STUCK OS.
I quickly went investigating and retracing my steps (they were still fresh) and a few event viewer logs confirmed my suspicions.
After going back to 314.22 all is well once more, I though it was important enough to share with you guys ;)  .
https://linustechtips.com/topic/21326-heads-up/
got bluescreens with all drivers after 320. (msi gtx 570)...
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/21326-heads-up/#findComment-257705
the 320 itself works for some reason...
https://linustechtips.com/topic/21326-heads-up/#findComment-257736
This doesn't necessarily apply, but I've been running the latest drivers on my 660 Ti with no problems whatsoever.
https://linustechtips.com/topic/21326-heads-up/#findComment-257754
I think its mostly problems with older cards...
https://linustechtips.com/topic/21326-heads-up/#findComment-257759
At first I posted 320.** because I could remember the exact value, it's 320.18.
I went over geforce.com to look at the change log and see if there are any optimizations regarding the 460
and stumbled upon a lot of comments describing the same problems I had! Coment Section
I gave up on this release.
https://linustechtips.com/topic/21326-heads-up/#findComment-257986
