I've had an ssd for ages but I've left my os on the hdd and installed 3dmax and photoshop on the ssd.
How can I clone my os on my ssd without having to do a fresh install?
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/212618-help-with-ssd/
I can't even........
I'll come back and answer in a while when I've calmed down from what I've just read.
https://www.youtube.com/watch?v=4w61JLpw_qU
https://linustechtips.com/topic/212618-help-with-ssd/#findComment-2887656
change the boot order to first your disk drive / usb depending on how you instal windows, then, put the ssd in second. when you will boot with a new windows, choose the ssd and select ''restore'' to cleare it. then boot using the ssd in first befor the hdd, then set up the partitions and clear the hdd from windows .. good luck
https://linustechtips.com/topic/212618-help-with-ssd/#findComment-2887661
well you can clone the full hard drive and that is it, 100% recommend to do a clean install. but my question is why have you bought an SSD and left the os on a HDD??????
CPU: i7 8700k Motherboard: MSI Z370 Krait Gaming RAM: 4x 8GB Corsair Vengeance Pro (2 white, 2 black) GPU: MSI RTX 2070 Armor Case: Corsair Crystal 570x White HDD: 2x 2TB Seagate Barracuda 7200rpm Sata 3 SSD: 240GB Corsair Force 3 + 500GB Samsung 970 Evo Cooling: Corsair Hydro Series™ H150i PSU: Corsair RM750i OS: Windows 10 Pro 64-Bit
Mouse: Logitech G600 Keyboard: Corsair K95 RGB Cherry MX Brown Monitor: Samsung S24C570L 1080p 23.6" + AOC AGON 240Hz 1080p Sound: HyperX Cloud Headset Black/Red + Logitech Z213 Speakers 2.1
https://linustechtips.com/topic/212618-help-with-ssd/#findComment-2887663
I answered your question in your original post.
Please don't double post.
"Rampage IV" - Gaming PC
Cooler Master HAF 932 Advanced    EVGA GeForce GTX 980                            ASUS VE278H 27in LED Monitor x 3
ASUS Rampage IV Black Edition         G.Skill Trident X 16GB DDR3 2400Mhz     Cooler Master Silent Pro Gold - 1000W
i7 4930k - Overclocked @ 4.5GHz     Samsung 850 SSD 250GB x2 RAID 0           Western Digital Blue 1TB
Logitech G930 Wireless Headset      Razer Naga 2012 MMO Gaming Mouse      Logitech G710+ Mechanical Keyboard
"EMCMS-ESXI" - Server
HPZ800 Workstation Chassis           Seagate 4TB NAS Drive x 4 RAID Z           48GB ECC Elpida DDR3 SDRAM
Xeon E5620 @ 2.66GHz x 2             PNY CS2211 240GB SSD                          HP 80 PLUS Silver APFC PSU - 1110W
LSI 9211-8i SAS in IT Mode
https://linustechtips.com/topic/212618-help-with-ssd/#findComment-2887750
