Hey.
Most of you guys have probably already seen this but this benchmarking tool is pretty funky.
It's called CatZilla and it's pretty self explanatory. You can pick it up here http://www.allbenchmark.com/
It offers something "interesting" you could say when you watch it in comparison to the 3DMark software.
Anyway use it or don't use it, none of by bussiness.
but if you do use it post your "cat" score ;)
My cat score is: 10750
if you'd like post some other quirky benchmarking tools because, why not?
while (true) {
    live();
https://linustechtips.com/topic/2125-catzilla-benchmarking/
Cat main test: Updated to 13,656
i5 3570K (4.5Ghz OC)|4x4GB 1600Mhz Corsair Vengeance pro|Zotac GTX 980 Amp! Extreme Edition|Asus p8Z77M-pro|Raidmax 500 80+Br| 128GB Kingston Now SSD|2x1TB Western Digital Blue| Artic White Define R4|Corsair H60 cooler|CM Storm Quickfire MX BLUE| White Corsair M65
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-29361
Kitty: 19141
Cat: 15915
Tiger: 9564
Catzilla: 5663
Intel i5 3570k | MSI GTX 670 Power Edition/OC SLI | Asus Sabertooth Z77 | Corsair Vengeance LP 16GB | Fractal Design Newton R2 650W | NZXT Switch 810 SE Gun Metal | BenQ 24" XL2420T 120Hz | Corsair K90  | Logitech G500 / Logtitech Performance MX | Sennheiser PC 360 | Asus Xonar DGX | NVIDIA GeForce 3D Vision 2 Wireless Kit
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-29386
kitty: 7357
Cat: 7540
Serious wtf moment here, i got better results at higher resolutions.
I really don't trust this, i have a XFX 7850 2gb @ 1ghz/1300MHz + 3570k @ 4.2GHz wouldn't run any higher than 720p even though I have a 1080p screen (tiger was greyed out) and the actual FPS in it at 720p was lower than other benchmarks that ran much better at 1080p (unigen). From what I have seen it seems to favour nvidia a lot. And obviously the inconsistent results I just had.
Other things i noticed in the video, cat uses 2xMSAA, except the actual quality was worse than games I have run that had no AA at all.
Arch Linux on Samsung 840 EVO 120GB: Startup finished in 1.334s (kernel) + 224ms (userspace) = 1.559s | U mad windoze..?
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-29413
  • 2 weeks later...
Bump
I'm going to reboot and run this, sounds awesome.
Alright my results:
7870@1050/1250 (default)
Kitty - 11588
Cat - 9472
7870@1200/1350 (game stable) :]
Kitty - 13232
Cat - 10744
CrossfireX 7870@1100/1250 (slight OC)
Kitty - 13981
Cat - 12044
3570k@4.7 1.31Vcore
Edit- Been playing with this bench for a few days now, I really like it :P I just run it for fun now.. I'm registered and on beta20
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-41903
I just now saw this being used to benchmark Ares 2. I run it tommorrow with fresh boot. I'm not waiting for any really high scores since my 560Ti is already 1,5 years old and running stock clocks. But gotta say that Catzilla test was really fun to watch.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-42366
whenever I try to run the benchmark it stops working and the windows troubleshooter comes up. I've tried installing/running in compatibiltiy mode and as administrator.
x64 windows 8. According to the website it supports windows 8 so I don't know why. :( Sorry I can't put up any results
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-42715
So here are my results:
Kitty: 17472
Cat: 14435
Tiger: 8944
CatZilla: 5320
I'm using a GTX670 with a GT640 for PhysX and a i7-3770K @ 4.5GHz
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-47531
After shutting my second monitor off and taking an average of 5 runs my result was:
Cat: 8946
Specs are in the signature.
"Wisdom III" AMD FX 8120 @ 4.1Ghz // Biostar TA990FXE // 16GB GeIL Black Dragon (8x2) // Saphire HD 7870 OC Edition // CORSAIR TX850M // Curcial M4 64GB (boot) // Seagate Barracuda Green 1.5TB (storage) // Cooler Master Hyper N 520 // Windows 7 Pro 64 bit
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-47625
kitty: 7357
Cat: 7540
Tiger and CatZilla are for paying members only (4 USD to be able to use Tiger, what I think is quite cheap). As for the scores, have you tried re-running it?
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-47655
I don't like this benchmark. Look what it recommends me to get:
And apparently getting a 6950 will get me more points than getting a 690. Even though I have a 7950.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-47711
Who cares what it recommends? it's just an awesome benchmark.
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-47797
I still prefer 3dmark
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-47810
but does 3Dmark have a cat with laser-beams ? hahaha
while (true) {
    live();
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-47907
kitty: 7357
Cat: 7540
The Tiger and CatZilla benchmarks were open to everyone earlier on, hence being quite annoyed, as for the results i was disappointed enough not to even bother, with nvidia cards being favoured so much in this I i don't see the advantage
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-47923
Only reason why you're saying that now is because its new. In a year this will be so boring no-one will use it. :(
Theres only so many times you can watch the same clip.
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-47958
That is a pretty demanding benchmark I must say.
Cat: 5048
BTW: my HD 7770 is OC'd from 1020MHz to 1150MHz :)
AMD FX-8350 // ASUS Radeon R9 280X Matrix // ASUS M5A97 Pro // Corsair Vengance 8GB 1600MHz // Corsair RM850 PSU //  WD Green 2TB // Corsair H60 // Cooler Master Elite 430 // KBParadise V60 MX Blue // Logitech G602 // Sennheiser HD 598 + Focusrrrrite 2i2 + MXL V67 // Samsung SyncMaster 245BW 1920x1200 // #killedmywife  #afterdark  #makebombs #Twerkit      "it touches my junk"   linus 2014
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-49588
Cat Score: 10719
Intel 2600k @4.5GHz
GTX 580 @ 900MHz Core Clock
My PC
  • CPU: i7 2600k @4.5GHz
  • Cooler: Corsair H100
  • GPU: EVGA GTX 580 SC
  • PSU: Corsair AX-850w
  • Motherboard: ASUS P67 Sabertooth
  • HDD: WD 1TB Black Caviar
  • RAM: Corsair 8GB Dominator
  • Case: Corsair 600T White Edition
  • Monitors: ASUS 23.6" 1920x1080
  • Mouse: Microsoft Sidewinder
  • Keyboard: Razor Blackwidow Ultimate
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-50077
  • 2 weeks later...
ALLBenchmark 1.0 BETA20
Cat Score: 14619
Intel 2500K @4.5ghz
MSI N680GTX Twin Frozr 2GD5/OC
Motherboard: ASUS P8Z68-V/GEN3 | CPU: Intel Core i5 2500k OC'd @ 4.5ghz | GPU: MSI N680GTX Twin Frozr 2GD5/OC | RAM: CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) | SDD: 120GB Samsung 840 EVO | HDD: 3 Western Digital 1TB  Hard Drives | PSU:Corsair Professional AX750 ATX12V & EPS12V Power Supply | Case: Corsair Carbide Series 300R Black Mid-Tower
https://linustechtips.com/topic/2125-catzilla-benchmarking/#findComment-58216
