help me build a cheap pc?
Go to solution Solved by dukeofangus,
thanks guys
used and recycled components
take a look through goodwill or something, sometimes they have some decent salvageable stuff or build 2nd hand off eBay/classifieds/OCN with a new PSU.
 I can make this at the cheapest from bottom of the barrel parts.
You will still need an OS from somewhere.
CPU: AMD 3850 1.3GHz Quad-Core Processor ($36.00 @ Amazon)
Motherboard: Gigabyte GA-AM1M-S2H Micro ATX AM1 Motherboard ($34.98 @ OutletPC)
Memory: Crucial Ballistix Sport 2GB (2 x 1GB) DDR3-1600 Memory ($25.95 @ Amazon)
Storage: A-Data Premier Pro SP600 64GB 2.5" Solid State Drive ($44.99 @ TigerDirect)
Case: BitFenix Merc Beta (Black) ATX Mid Tower Case ($19.99 @ NCIX US)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply ($26.98 @ Newegg)
Total: $188.89
Generated by PCPartPicker 2014-09-10 00:04 EDT-0400
Error: 410
https://linustechtips.com/topic/212465-help-me-build-a-cheap-pc/#findComment-2885204
I would think your better off buying a refurbished optiplex with a C2D for your grandparents then buying computer parts that aren't that good.
I'll try to make a pcpartpicker link for around 200
CPU: AMD 2650 1.45Ghz Dual-Core Processor  ($28.00 @ Amazon)
Motherboard: Biostar AM1ML Micro ATX AM1 Motherboard  ($31.98 @ OutletPC)
Memory: Team Elite 2GB (1 x 2GB) DDR3-1333 Memory  ($20.99 @ Newegg)
Total: $151.44
Generated by PCPartPicker 2014-09-10 00:05 EDT-0400
I wouldn't really recommend this build, your better off buying a cheap chromebook or a refurbished optiplex with a C2D
https://linustechtips.com/topic/212465-help-me-build-a-cheap-pc/#findComment-2885209
This?
CPU: Intel Celeron G1840 2.8GHz Dual-Core Processor  ($42.99 @ NCIX US)
Motherboard: MSI H81M-E33 Micro ATX LGA1150 Motherboard  ($44.99 @ Micro Center)
Storage: Western Digital WD Blue 320GB 2.5" 5400RPM Internal Hard Drive  ($39.89 @ Amazon)
Case: HEC Vigilance MicroATX Mini Tower Case  ($24.99 @ Amazon)
Power Supply: Antec Basiq 350W ATX Power Supply  ($29.98 @ OutletPC)
Total: $203.83
Generated by PCPartPicker 2014-09-10 00:02 EDT-0400
I really wouldn't recommend it.
https://linustechtips.com/topic/212465-help-me-build-a-cheap-pc/#findComment-2885222
CPU Cooler: Zalman CNPS80F CPU Cooler  ($7.99 @ Mwave)
Motherboard: Intel DQ45EK Mini ITX LGA775 Motherboard  ($73.50 @ Amazon)
Video Card: HIS Radeon HD 5450 1GB Video Card  ($72.98 @ Newegg)
Power Supply: Inwin 350W ATX Power Supply  ($13.98 @ Amazon)
Total: $264.25
https://linustechtips.com/topic/212465-help-me-build-a-cheap-pc/#findComment-2885231
Total: $188.89
This is good but I think a 120gb would be better for the ssd. A 120 kingston now is only about 60.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/212465-help-me-build-a-cheap-pc/#findComment-2885312
