Cable sleeving or extensions
By
JihadGrandad
in Cases and Mods
in Cases and Mods
Solved by Enderman,
It is MUCH easier to buy extensions. Also, you're using a non-modular PSU so sleeving them yourself will be far more complicated then it already is.
If you have no previous experience with modding PSUs and cables, definitely go with sleeved extensions. (it will cost about the same as sleeving them yourself)
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
Posted in New Builds and Planning4 -
5
3
Doctah ·
Posted in Peripherals3 -
8
michaelb198 ·
Posted in Peripherals2
