I just built my first gaming PC with a gigabyte gtx770 4gb oc version graphics card. I have no previous experience of overclocking and i am trying it for the first time.
i went through some articles on the internet and got the maximum overclock that the card can do according to the articles.
i am just looking at the numbers and it seems to me that maybe i can get just a little more from the card. I overclocked the clock to 1280Mhz and memory to 7400 mhz and they stay there for extended amounts of time and the temperature caps at 75 C under load (valley benchmark and watchdogs regular game-play at 1920x1080 at max settings. one at a time). Now i don't have AC in the room where the PC is and the mini fridge that i have sits right next to the case [easy access ;)]. The ambient temperature right now is 35 C and in summer can go upto 47.
I am just wondering what is the max any of you have gotten from the card as i see that i have a bit of wiggle room with temperature and currently i haven't changed the voltage.
Or if you can point to an article the has some tutorial or guide about how to increase the different frequencies.
Thank you
https://linustechtips.com/topic/210670-need-help-with-gtx-770-overclock/
Mine is at 1260MHz with max power limit and core voltage, and stays under 70C
