NZXT's new S340 looks amazing. Rolled steel and all. I would buy it when it comes out for $69.99
https://linustechtips.com/topic/209844-best-100-case/#findComment-2848390
NZXT H440, NZXT Phantom 430 if optical drive bay is important. Corsair 500R.
"The only person you are destined to become is the person you decide to be."
CPU: Intel i5 4690K - Motherboard: Asus Maximus VII Ranger - RAM: Corsair Vengeance LP - 2x4GB @ 1866Mhz - GPU: MSI Twin Frozr GTX 770 4GB - CPU Cooler: Be Quiet! Dark Rock Pro 3 CPU Cooler - PSU: EVGA SuperNova G2 750W - Storage: Seagate Barracuda 2TB HDD- Case: Fractal Design Define R4 Windowed (with Red AKASA Led Strips) - Display: Benq GL2460HM 24" Monitor
https://linustechtips.com/topic/209844-best-100-case/#findComment-2848393
H440, Enthoo Pro, Source 340.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/209844-best-100-case/#findComment-2848402
I really wanted to mash the like button over that case..
S340. :)
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/209844-best-100-case/#findComment-2848423
I would get that and mod the front panel! Why do they make so restrictive cases these days? I'd make some cuts on the front, add a high quality triple fan grill (like the ones made by Mnpctech).
https://linustechtips.com/topic/209844-best-100-case/#findComment-2848439
Its much easier to drill some holes in the front than it is to fill in holes.
On a side note, it would be really cool if NZXT made an airflow designed body for the H440/S340. I.e. they would sell the regular H440, but then have an additional top and front panel that are designed with airflow rather than silence in mind that you could just buy and swap with the stock panels.
PSU Tier List | CoC
https://linustechtips.com/topic/209844-best-100-case/#findComment-2848470
the S340 has better airflow than the H440. The NZXT rep on Reddit was mentioning that..
@syrazpc - for all my rambles about PC's -- My Gallifreyan Build In Progress
https://linustechtips.com/topic/209844-best-100-case/#findComment-2848485
Thank you to all of you replying I have decided on the H440
Nice, i love the H440, it's what my main rig is in. I think it's a great case, just maybe not the best for watercooling
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/209844-best-100-case/#findComment-2853713
The s340 is a better case, in build, price, and size.
https://linustechtips.com/topic/209844-best-100-case/#findComment-2854367
But I want the system now
Wait a few weeks, not sure when it comes out, but waiting is better than hating
https://linustechtips.com/topic/209844-best-100-case/#findComment-2855045
Corsair 450D.
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
https://linustechtips.com/topic/209844-best-100-case/#findComment-2864304
