FX6300 without cooler...
Go to solution Solved by Tro,
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
And yes, It does come with a stock cooler.
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
https://linustechtips.com/topic/209563-fx6300-without-cooler/#findComment-2843970
NO.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/209563-fx6300-without-cooler/#findComment-2843972
No you cannot run a CPU without a cooler.
Yes it comes with a stock one.
https://linustechtips.com/topic/209563-fx6300-without-cooler/#findComment-2843976
If you want to cook bacon on it then sure, otherwise no... mmmh.. bacoooon
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/209563-fx6300-without-cooler/#findComment-2843985
You will need to cool it somehow, don't run it without adequate cooling.
If you bought a retail boxed version you will get a stock heatsink/fan along with a manual in the box. If you bought an OEM or 'tray' version... you will just receive the processor on it's own.
https://linustechtips.com/topic/209563-fx6300-without-cooler/#findComment-2844051
