System doesn't POST
Solved by nanowatt,
Much to my surprise, I do have a point for my speaker...
as soon as I find it, i'll let you know my results.
@nanowatt. I didn't know AMD had issues with their temp sensors..
I do have a warning and a shutdown. warning is at 88, shutdown is at 90, system worked as I tested on assembly (three years ago, mind you) warning popped up, and the system shut down about 30 seconds later.
CMOS was cleared
MoBo was pulled, no visual damage to the board anywhere. Forgot to mention that part.
You fried the poor processor.YOU merciless beast!
