Hi, I have my 3570k at 4.4GHz. Core Temp and CPU-Z displays it as 4.4GHz.
Start menu > Computer > Properties displays 'i5 3570k @ 3.40GHz 3.40GHz'. If it makes a difference, I have turbo boost on for some settings (forgot what they were called), but the turbo multipliers are at 44.
Which one is correct, and which one should I ignore?
https://linustechtips.com/topic/20867-overclock-speed-display-question/
Ignore the one from the start menu.
Cpu-z has it right.
No. You're fine. Your CPU is at 4.4GHz. As long as the BIOS and CPU-Z (and other programs like Core Temp) report your 4.4GHz overclock, you're fine. Ignore the processor properties in Windows.
Don't worry about it, mine just says its 3.50Ghz, even though its 4.3Ghz, doesn't even say @blah ghz
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
