budget?
uses?
Specs
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814216
Mostly gaming, and some rare video editing. my budget is about 2200 USD. I live in Denmark so the prices might differ.
Whats your budget in your currency?
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814224
here, felt in the mood to go pure over kill because of your budget if you can't afford it or want changes ill make some if needed
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.99 @ Newegg)
Motherboard: Asus SABERTOOTH Z97 MARK 1 ATX LGA1150 Motherboard  ($238.99 @ Newegg)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive  ($228.95 @ Amazon)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card (2-Way CrossFire)  ($364.99 @ Newegg)
Total: $2078.18
Generated by PCPartPicker 2014-08-31 07:25 EDT-0400
Specs
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814230
Total: $2078.18
Are the RAM fast enough? Or do they need to be faster to overclock the CPU?
I don't need an HDD since i have an NAS with enough storage. Are the H100i better than the H105? The H105 has a thicker radiator
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814250
what do you mean? the rams more than enough
Specs
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814256
Okay, i never really overclocked a CPU, my first was a i7 920.
But should i go for the H100i or the H105, the H105 has a thicker radiator
it wont fit in the r4 though, if you want a thicker rad either go with the nzxt x61 and h440 or switch the case of the linked set up to something like a corsair 450d
Specs
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814262
this ?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($279.99 @ Micro Center)
Motherboard: Asus SABERTOOTH Z97 MARK2 ATX LGA1150 Motherboard  ($165.99 @ Amazon)
Memory: Kingston Fury Black Series 16GB (2 x 8GB) DDR3-1866 Memory  ($159.99 @ NCIX US)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($83.49 @ OutletPC)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($99.99 @ Micro Center)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($146.81 @ Newegg)
Total: $1985.18
Generated by PCPartPicker 2014-08-31 07:40 EDT-0400
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814267
I made some chanages
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($114.99 @ Amazon)
Case: Corsair 760T Black ATX Full Tower Case  ($139.99 @ NCIX US)
Total: $2079.69
Generated by PCPartPicker 2014-08-31 07:41 EDT-0400
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814268
Motherboard: Gigabyte GA-Z97X-GAMING 7 ATX LGA1150 Motherboard  ($157.50 @ Newegg)
Total: $1956.38
Generated by PCPartPicker 2014-08-31 07:44 EDT-0400
What resolution are you gaming at ?
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814274
Total: $1956.38
no HDD ??
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814277
Total: $1956.38
Currently 1920x1080, but i thought about getting a 34 inch 21:9 monitor
I changed the GPU and PSU
Total: $2028.27
Generated by PCPartPicker 2014-08-31 07:45 EDT-0400
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814281
Total: $2079.69
just use mark 2 it's cheaper
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814282
 Or the Z97-PRO?
Is the PSU large enough here?
Motherboard: Asus Z97-PRO ATX LGA1150 Motherboard  ($169.20 @ Newegg)
Total: $1958.48
Generated by PCPartPicker 2014-08-31 07:48 EDT-0400
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814289
No, 500 GB SSD is large enough. I have a NAS with 4+ TB storage
ow okay
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814293
 Or the Z97-PRO?
Total: $1958.48
A 760W will allow for a 2nd 780ti. I would suggest the EVGA Supernova G2 850W though, as it is cheaper, with a bit more headroom.
http://pcpartpicker.com/part/evga-power-supply-220g20850xr
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814298
http://pcpartpicker.com/p/qfMLdC
This is about 440 USD more in Denmark, than in USA :(
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814312
Looks ok, Maybe an EVGA PSU (your choice), I'd recommend a 450D instead of the 760T, maybe u[grade to 6GB of VRAM (if you plan going multi monitor or 4k), maybe an H100i for the water cooler and I dont know if you need the full 16GB of RAM (are you editing and stuff?).
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814319
Why the 450D instead of an 760T? i prefer the looks of the 760T. The H105 has a thicker radiator and i don't need Corsair Link. I do occasionally edit videos and run virtual machines so 16 would be nice.
https://linustechtips.com/topic/207425-first-build-in-4-years/#findComment-2814424
