Hi Everyone,
I was wondering if I can get PC designed for me??
Budget & Location - The budget is around $2000 and location is Australia 2330 so $AUD
Aim - I want to be able to use this PC for gaming and Audio recording so I will be using Protools which requires 16 GB if RAM things and the games I will be playing will pretty much be anything.
Monitors - I will use 2 monitors but maby get a 3rd in the future the monitors are - BenQ EW2440L 24in at 1920 x 1080 2 of those.
Peripherals - No need I have keyboard and mouse ETC.
Also I would like a corsair case with window and some sleeved cable which I would like to go with a black and white theme.
I am upgrading because PC is old and I want a new one as I want to start to do heavy work on Protools and my PC is not capable of running it well.
Thanks for the help!   :)
Scott
https://linustechtips.com/topic/206977-pc-help/
2330 Australian Dollar With Monitor ? or only pc ?
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/206977-pc-help/#findComment-2808207
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($389.00 @ CPL Online)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($149.00 @ CPL Online)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($219.00 @ CPL Online)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card  ($499.00 @ Mwave Australia)
Case: Corsair 300R ATX Mid Tower Case  ($99.00 @ CPL Online)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($187.00 @ CPL Online)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($115.00 @ CPL Online)
Monitor: BenQ EW2440L 60Hz 24.0" Monitor  ($199.00 @ CPL Online)
Total: $2353.00
Generated by PCPartPicker 2014-08-31 03:57 EST+1000
This is slightly over $2330 but very powerful indeed.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/206977-pc-help/#findComment-2808234
@Scotty123553
with SSD Maybe for OS
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($32.00 @ Centre Com)
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard  ($170.00 @ Centre Com)
Memory: Kingston Fury White Series 16GB (2 x 8GB) DDR3-1866 Memory  ($188.00 @ CPL Online)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($79.00 @ CPL Online)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($62.00 @ Centre Com)
Video Card: MSI Radeon R9 290 4GB TWIN FROZR Video Card  ($449.00 @ Mwave Australia)
Case: Corsair 600T White Graphite ATX Mid Tower Case  ($199.00 @ CPL Online)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($259.00 @ Mwave Australia)
Monitor: Asus VE247H 23.6" Monitor  ($179.00 @ Mwave Australia)
Case Fan: BitFenix Spectre Pro LED 56.2 CFM 120mm  Fan  ($14.00 @ CPL Online)
Total: $2328.00
Generated by PCPartPicker 2014-08-31 04:05 EST+1000
https://linustechtips.com/topic/206977-pc-help/#findComment-2808299
updated
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($104.00 @ CPL Online)
Total: $2290.00
Generated by PCPartPicker 2014-08-31 04:16 EST+1000
https://linustechtips.com/topic/206977-pc-help/#findComment-2808395
Total: $2353.00
jeez you got overpriced PSU Right there
https://linustechtips.com/topic/206977-pc-help/#findComment-2808412
Actually go to Pcpartpicker, select australia (Something tells me you forgot this is AUD and not USD) and filter the PSU's on 850-860W and you will see that the G2 is far from overpriced.
https://linustechtips.com/topic/206977-pc-help/#findComment-2808424
yeah it's overpriced
https://linustechtips.com/topic/206977-pc-help/#findComment-2808455
Yeaaah, it really isn't. It's cheaper than the RM850 and the G2 scores higher than the RM850.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=369
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=377
https://linustechtips.com/topic/206977-pc-help/#findComment-2808460
Hey everyone thanks for the replys do you think you could also include The corsair 750D I think it is that one. I love the look of that case and windows 7 not 8 also if use could include sleved cables??
thanks
Scott
Much is possible but until it is known if monitors and o/s have to be included in the build it is not possible to answer the question.
https://linustechtips.com/topic/206977-pc-help/#findComment-2816057
Well the monitors dont have to be included and the OS dose have to be included
It is not a Corsair case but I think it will do a better job with the black & white theme. Going with the 750D would add about AU$50 to the cost. The sleeved cables shown are from Newegg and include an approximation of shipping costs, in AU$. You may be able to find the part locally.
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($195.00 @ CPL Online)
Memory: A-Data XPG V1.0 16GB (2 x 8GB) DDR3-1600 Memory  ($179.00 @ PCCaseGear)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($62.00 @ Centre Com)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  ($455.00 @ Mwave Australia)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($158.00 @ CPL Online)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($148.00 @ CPL Online)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($115.00 @ CPL Online)
Other: Individually Sleeved Cable Set for EVGA B2/G2/P2 Power Supply / PSU (White) - EVGA 100-CW-1300-B9  ($146.18)
Total: $2075.18
Generated by PCPartPicker 2014-09-01 13:58 EST+1000
https://linustechtips.com/topic/206977-pc-help/#findComment-2819907
Total: $2075.18
Could you also include some black/white sleved cables aswel
https://linustechtips.com/topic/206977-pc-help/#findComment-2820714
There is an all white sleeved cable set for the psu at the bottom of the list (see Other). The cable set that comes with the psu are black-sleeed. So just mix and match the two sets to meet your needs.
https://linustechtips.com/topic/206977-pc-help/#findComment-2824478
