Im doing a class project for my school and I need to build a budget PC and a high end PC and explain all the parts.
My question is, How are the way storage is saved on SSD's different for the way there stored on a HDD.
If anyone wants to give me pointers: https://docs.google.com/document/d/155QF7SattL2JFJUZKWw2lvThDEASDzneSvcgL_XO34s/edit?usp=sharing
Fedex Ground must be on Horse back, It took 7 days to go 200 miles
https://linustechtips.com/topic/206933-hard-drive-question-class-help/
SLI and CFX are only able to do 4 way not 5 way.
This explains all you need to know about HDDs and SSDs
http://en.wikipedia.org/wiki/Solid-state_drive
http://en.wikipedia.org/wiki/Hard_disk_drive
http://www.pcmag.com/article2/0,2817,2404258,00.asp on SSDs vs HDDs I recommend in the budget PC just throwing in a Baracuda HDD on the highend one go NUTZ
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
HDD stores data kinda similair to a CD, it stores it on a spinning disk that's getting read.
SSD's are like SD cards or USB sticks, it stores data on a chip instead.
Not sure if that's enough info, it's all i know :P
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
Hard drives are a set of spinning magnetic platters that are written to and read from with a Little Arm controlled by a Electromagnet.
It's very similar to a Record player actually. Except the disk spins much much faster, the Little arm can actually write information and The arm moves back and forth across the disk very quickly.
SSDs on the other hand use NAND flash which is a form non-volatile (Doesn't lose info when power is lost) Memory with no moving parts, the same kind used in a USB thumbdrive. SSDs are very fast because they 're no moving parts and when information is needed from another sector of the disk you don't have to wait for anything and can start reading.
A riddle wrapped in an enigma , shot to the moon and made in China
