295x2 Custom water cooling?
Solved by nj4ck,
As for connecting acrylic tubing to the stock blocks, I don't see a way it could be done. The fittings for hardlines are pretty thick in diameter and would likely not fit inside the aluminum shroud, that is if you somehow manage to fit them to the asetek blocks. What I would do instead is get a block like this:
and plasti-dip it to make it look something like this
as for the sanding, it should probably work, you should be able to see by taking a close look at it if the color is painted on or if the actual plastic is colored red.
