Sennheiser momentum help!
They are worth the money if you really need the style factor.
I would get AT m40x for travelling, much cheaper so you can throw them around more and not care :D
https://linustechtips.com/topic/205283-sennheiser-momentum-help/#findComment-2786412
I do personally own them, the Brown variant.
They are well built, nice usage of materials, great sound, perfect durable carrying case. The only con is, that you are indeed paying premium for the stylish design.
But I can really recommend them.
G4MING RIG - CPU: i7 5930K  Cooling: Custom Loop  MOBO: Asus Rampage V Extreme  GPU: EVGA 980 Ti GTX Classified  RAM: Corsair Dominator Platinum DDR4 16 GB  SSD: Samsung 840 Pro  PSU: be quiet! Dark Power Pro 11 850W Platinum Certified  Sound: Asus Xonar Essence STX II  CASE: Phanteks Enthoo Primo  PERIPHERALS: Das Keyboard Ultimate 4, Logitech G502 Proteus Core, Sennheiser G4ME One, B&W MM-1, ROG SWIFT
Macbook Pro Retina 15" 2012CPU: i7 2,7 GHz  GPU: GT 650M,  RAM: 16GB,  SSD: 512GB
https://linustechtips.com/topic/205283-sennheiser-momentum-help/#findComment-2786584
Try before you buy - they only sound good if they seal around your head well, but they don't seal correctly for everyone.
https://linustechtips.com/topic/205283-sennheiser-momentum-help/#findComment-2788747
The Momentums are on ear headphones, not over the ear by the way
http://en-us.sennheiser.com/over-ear-headphone-momentum-stereo
but they sound great! better than m50's, and mdr-1r's.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/205283-sennheiser-momentum-help/#findComment-2789281
Ehhh. Ive been using them for travel for about a month now. I have a pretty big head so I was initially worried abouting them sealing well/ being comfortable. I just bent the metal a bit and adjusted the ear cups and now they fit great. I'm sure you could find something that sounded better for £250 but you really are paying for how small and good looking they are. I don't think i'd pay more that $200 for them.
https://linustechtips.com/topic/205283-sennheiser-momentum-help/#findComment-2789976
