https://linustechtips.com/topic/204095-watercooling-help/
bitspower
https://linustechtips.com/topic/204095-watercooling-help/#findComment-2771288
Really any 3/8 id 5/8 od fittings compression fittings that suit your budget. I.e. Something like these: http://www.amazon.com/gp/aw/d/B0060861IG/ref=pd_aw_sims_6?pi=SL500_SS115
Just remember you need two per item. Could I also suggest a water block for that gpu? http://www.amazon.com/gp/aw/d/B00H3IXTLO/ref=mp_s_a_1_1?qid=1409009040&sr=8-1π=SY200_QL40
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
https://linustechtips.com/topic/204095-watercooling-help/#findComment-2771340
https://linustechtips.com/topic/204095-watercooling-help/#findComment-2771548
I'm building this build http://pcpartpicker.com/p/FRktLk
these are the watercooling parts
radiator http://www.amazon.com/gp/product/B00IAC5456/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A3JR0YCXC6EG04
tubing   http://www.amazon.com/gp/product/B00A9ZDHX8/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A15YNZR7YB053N
reservoir/pump combo http://www.amazon.com/gp/product/B00A42X2KY/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=A28CFGAEH1L7HN
cpu waterblock      http://www.amazon.com/gp/product/B005T01B54/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=A1S9W9A986D3KF
biocide   http://www.amazon.com/gp/product/B00A66HMRC/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=A3JR0YCXC6EG04
i need to know what fittings i need to buy
and your other suggestions thanks
EDIT im using  a EVGA 1300G2 PSU now I think
Everything except the pump/res combo is worth it. I have that same pump/res combo and yes it has worked well and still does but it is not the best and if you decide to make any additions to your loop you will have to change the pump so you might as well get a better one now.  Anything in the D5 line up is excellent.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/204095-watercooling-help/#findComment-2771746
can u give a link to them?
https://linustechtips.com/topic/204095-watercooling-help/#findComment-2772521
This will work nicely if you want the 5.25" bay pump/res combo and this for the tube res/pump combo.
This is just a list of D5 pumps. I use these for my radiator and they work lovely and at the price you will not find better at this point in time.
For fittings you can either use plain barbs or compressions. Pay attention to the fitting size you are  so you will know the proper tubing size to get which will minimize leaks.
https://linustechtips.com/topic/204095-watercooling-help/#findComment-2772678
