I'm building a pc and the only im left out with is a case and a power supply.
I need one so it can meet the needs for the requirements below:
CPU: Intel i-5 4690k
CPU cooler: Noctua NH-14 65.0 CFM
GPU: EVGA Nvidia Geforce GTX 760 2GB superclocked ACX
Memory: Corsair Vengeance Pro 16 GB ( 2x8 ) DDR3 - 1600
Internal hard drive: Western Digital caviar blue 1TB 7200 rpm
Motherboard: msi Z97-gaming 5 ATX LGA1150
Help is appreciated
https://linustechtips.com/topic/203927-best-case-and-psu/
Help is appreciated
600W power supply would work. Case choice is up to you depending on how much you want to spend and the looks of the case.
https://linustechtips.com/topic/203927-best-case-and-psu/#findComment-2768948
Need a budget before suggestions can be made, OP. As long as you don't plan to OC, a 500W branded 80+ bronze PSU will suffice for that setup, as long as you don't plan on SLI'ing in the future.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/203927-best-case-and-psu/#findComment-2768955
Get a Fractal Design Define R4, it's currently on sale at NCIX. Also get an EVGA G2 750W, just in case you ever SLI or OC in the future. Do you need help building it?
The power supply is sufficient , but i honestly dont adore the case design. Its really plain. And for putting it together i can handle that.
Is there any other cases you would recommend
https://linustechtips.com/topic/203927-best-case-and-psu/#findComment-2769096
