Every time i try to connect at same time headphones and any kind of usb in the front pannel i get this "interference" ,all my back usb ports are taken,and i always play with headphones..I have no idea how resolve this problem,since i need to plug in my wireless mouse in the front pannel,otherwise i have to remove all other things from back pannel...Any suggestion? Thanks
https://linustechtips.com/topic/203496-headphones-annoying-problem/
Are your headphones plugged into the front audio jacks?
What do they know of England, who only England know?
"Well that's what I always said I wanted to be remembered for, for being honest. Nothing else is worth a damn"
Yes.And i cant plug them back since cable is too short
Then that will most likely be the issue. Even though the cable it too short, move your PC to test to see if the same issue happens when the headphones are plugged in round the back.
yea the cable that goes from the motherboard header to the front panel header is getting interference if i were you i get a extension from the back
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
No way to change that cable instead getting extension from back? Since my pc is in really in really tight place
When i plug the cable back i dont get this problem.Still my headphones cable is about 1 meter long...Theres nothing i can do to remove the interference?
Sorry for late answer,i was super busy...Thanks for fast answers :)
I don't believe there is other than plugging in directly to the back, I am afraid.
