Hello,
Here is a build that I have planned out. What are your thoughts?
Case: Corsair 350D
CPU: i5 4690k
GPU: EVGA GeForce GTX 770 Dual SC ACX 4GB
Motherboard: Asus Gryphon Z97 Motherboard
Memory: Kingston Hyper X Fury Black 1866Mhz 8GB (2x4GB)
PSU: EVGA SuperNOVA 750W G2 Power Supply
Storage: Seagate SSHD 4TB
CPU Cooler: CoolerMaster Hyper TX3 EVO
Upgrades:
  • Asus Gryphon Armor Kit
  • Swiftech H220-X AIO Liquid Cooler
  • Samsung 840 EVO Series 250GB SSD
  • NZXT RGB Hue LED Controller
  • 2nd GPU (much later)
Thanks,
SnowGhost
https://linustechtips.com/topic/203127-micro-atx-build-plan/
Looks good  :)
Ola Englund does not approve of your hashtags. Sleep is for the weak, insomnia builds character.
As you are reading this you are slowly traveling forwards in time to where you will get out of the time machine and continue to read posts. Too spookyfor100me.
https://linustechtips.com/topic/203127-micro-atx-build-plan/#findComment-2757389
The 350D is butt ugly if you actually utilize a 5.25 bay. For whatever reason, Corsair's design team thought it was a great idea to make the bays inset instead of flush which means the clean looks of the front is completely ruined. Look at 350D's that actually have a bay device installed.
https://linustechtips.com/topic/203127-micro-atx-build-plan/#findComment-2757432
Yes, I realise that. I was planning to mod the LED Controller. Cut off the plastic tray (since the PCB is at the front) and mount it somewhere else inside the case.
https://linustechtips.com/topic/203127-micro-atx-build-plan/#findComment-2757436
That would work. I like the looks of the 350D, just not the bay design.
https://linustechtips.com/topic/203127-micro-atx-build-plan/#findComment-2757453
