Hey LTT,
So the title may be a little misleading. I'm looking for a MMO mouse for FPS games. What I mean is that I want buttons on the side. Right now I use a Razer Naga 2012. I use 4 of the 12 buttons on the side for FPS games and I can't go back to a regular mouse. I use it for sprint, crouch, prone and knife. So my question is what is the best mouse that has 4 fully programmable buttons that is under $200?
Thanks!
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/203068-best-mouse-for-fps/
corsair m65 but only has 3 or corsair m95
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/203068-best-mouse-for-fps/#findComment-2756516
Logitech G402 or G502. I can't believe I'm saying this, but they're better than the almighty DeathAdder.
I really really like the look of that mouse, but it doesn't look very omfortable to me.
Looked it up. The M95 would be better for gaming overall? I could deal with losing knife on my mouse I guess.
Razer DeathAdder is always a good choice.
No buttons bruh
Logitech G502.
Really like how it looks.
The new Razer Naga or that Logitech mmo mouse. Both are nice.
I personally went with the new Naga after giving my older one away to a friend.
How do you like the new naga? Is it worth it over the old one?
https://linustechtips.com/topic/203068-best-mouse-for-fps/#findComment-2756547
No buttons bruh
what games do you play, i know that most fps games you dont get opportunity to knife anyway
My Rig
Total: $2074.22
https://linustechtips.com/topic/203068-best-mouse-for-fps/#findComment-2756561
Linus reviewed it a month or so ago and it's actually really comfortable. It does look uncomfortable though, lol.
"You have got to be the biggest asshole on this forum..."
-GingerbreadPK
sudo rm -rf /
https://linustechtips.com/topic/203068-best-mouse-for-fps/#findComment-2756567
The major difference is the size of the mouse. I found the older iteration to be small, and even the interchangeable side grips wouldn't help with my fingers being uncomfortable during long sessions.
So with this being a bigger mouse, it fits in my hand better and it's easier to handle ( ͡° ͜ʖ ͡°)
Plus it has mechanical buttons instead of those hard to press membrane keys on the last one. The down side is right off the bat you won't be used to how much less pressure it takes to press the button, so you'll be sliding the mouse around and pressing buttons that you don't want - I did anyways.
It feels like there's a grippy-er texture on the mouse itself too, which feels nice.
https://linustechtips.com/topic/203068-best-mouse-for-fps/#findComment-2756602
Hmm that does address every issue I've had with the mouse. I'd think I want to get away from razer though. About 70/30 in logitechs favor right now.
wait for the tyon.
The wat?
I actually just watched that now. He seems to like it though I don't know how well it would go with the green mousepad and white keyboard.
Play a lot of battlefield but the F key shouldn't be too hard to reach.
https://linustechtips.com/topic/203068-best-mouse-for-fps/#findComment-2756662
There's no "best mouse". Go to your local store and get a feel for what you like. As for dpi, there's absolutely no need to get anything above 3500dpi.
In the end, it's all marketing bullshit.
i7 7700k @ 4.9ghz | Asus Maximus IX Hero | G.skill 32gb @ 3200 | Gtx 1080 classified | In win 909 | Samsung 960 pro 1tb | WD caviar blue 1tb x3 | Dell u3417w | Corsair H115i | Ducky premier dk9008p (mx reds) | Logitech g900 | Sennheiser hd 800s w/ hdvd 800 | Audioengine a5+ w/ s8
https://linustechtips.com/topic/203068-best-mouse-for-fps/#findComment-2757594
Nvm hadn't read op post fully.
It is said, that civilised man seeks out good and intelligent company, so that through learned discourse he may rise above the savage and closer to God. Personally, however, I like to start the day with a total dickhead to remind me I'm best!
https://linustechtips.com/topic/203068-best-mouse-for-fps/#findComment-2761734
