Building and Upgrading. what di you think?
Solved by Titania_WD,
Hi martheus25,
On your question: The recommended power for the Zotac Geforce GTX 760 is 600W, whereas the max power consumption is indicate to be 170-watt. For the GTX 770 again 600W is the recommended power supply, while the max power consumption is said to be of 230 W.
About the storage: I see you already have a 1TB WD Blue drive. This should be just fine. However, for heavy gaming I'd suggest an upgrade with WD Black (http://www.wdc.com/e...cts.aspx?id=760). With their performance, the WD Black drives are designed especially for gamers.
Hope this helps,
Titania_WD
