Hey forums,I wanted to ask you guys about my configuration.About a year ago I bought a computer from bestbuy that had an AMD apu which was great.Than I decided to upgrade my power supply and my graphics card to a geforce 650 ti Boost edition card.For some reason whenever I open up a game like cs:go or even Minecraft. My graphics card gets hot and Its quite annoying.ANY TIPS TO MAKE MY PC QUIETER WITHOUT THE EXPENSE? And if I do have to get fans or a better cooler what can I get for a average price?Thanks,looking forward to some answers.
https://linustechtips.com/topic/201767-my-load-pc/
download MSI afterburner
using the program
you should be able to set a fan curve which auto runs the fan at a certain speed for your GPU
if your APU is still using the stock cooler
you might want to invest on the CoolerMaster T4 cooler which is a bolt on solution
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/201767-my-load-pc/#findComment-2736156
Don't block any air intakes or exhausts, perhaps try cleaning the dust out of the PC if there is any? (compressed air works great, just be sure to use it in short bursts)
https://linustechtips.com/topic/201767-my-load-pc/#findComment-2736188
I downloaded afterburner but the settings of the fans get louder as I turn the game up. I use my computer for recording,editing,rendering and gaming so I think I would need to get a new case and more fans.
You haven't even told us what model card it is.
If it's the EVGA SC blower then you're just going to have to deal with it. Pick between acoustics or temperatures; blowers don't let you have both.
https://linustechtips.com/topic/201767-my-load-pc/#findComment-2736336
Which version of the GTX 650 Ti Boost have you got?
https://linustechtips.com/topic/201767-my-load-pc/#findComment-2738636
i think I have the pny edition'
It would be nice to know the temps you are getting
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/201767-my-load-pc/#findComment-2747209
You know what, can you take a picture for us? That would make it much easier to figure out.
PNY has at least 3 models of the GTX 650 Ti Boost: 1) the reference blower, 2) dual-fan, akin to TF3 or Sig2 and 3) a GTX 560 Ti-style single-fan design.
You also need to tell us the specs of the rest of your system. CPU, mobo, drives, case, PSU, etc.
https://linustechtips.com/topic/201767-my-load-pc/#findComment-2752155
