R9 290X Lightning VRM cooling
Solved by Freaky_spider,
is monitoring software accurate? Actually I don't believe much like realtemp or similar kind of things.
what I know is temp on software is just a guess. Calculated by Tjmax and voltage. Is this only applies to CPU? or same with GPU?
nono, lightning cards have equal temp probes
they might not be 100% accurate, but its not gonna be that far off
note that VRM generally gets hot because there is little area to cool it, and it can handle high temps, the ones a lightning has are rated at 105°C (or 115°C, cant remember correctly)
