Help determining PSU wattage
Go to solution Solved by TheSpottedCow,
@dragoon20005
Awesome link. His cards were pushing out 860 when he had them at the highest.
@Geekazoid
7000W could probably power my house. :D
@Mateyyy
lol Please give me a nuclear reactor, I would power my neighborhood and BE RICH.
Mateyyy and dragoon20005, 1000 watts it is! Thanks guys. B)
Hello all. I have a build list for my new pc and I need enough power to run this rig with 7 case fans.
I'll add these on later after I save up some more $:
second 290x
second ssd and/or hdd
water cooling loop for the GPU's and CPU
I might do a little OC'ing to the GPU's too
Here is the list:
http://pcpartpicker.com/p/2TpJpg
Any help much appreciated. :)
https://linustechtips.com/topic/200678-help-determining-psu-wattage/
since you will be watercooling and OC the GPUs
go for at least 1K watts PSUs
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
You'd be fine with a 850W PSU
Just go completely overkill and opt for a 7,000W PSU. :P (JK)
@TheSpottedCow
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
that is with air cooling
http://linustechtips.com/main/topic/168268-r9-290-crossfire-total-system-power-consumption-ax860i-results-at-different-overclock-speeds-water-cooled/
this guys confirmed that with watercooling and OC
it will draw above 850 watts
A Nuclear Reactor.
Seriously now, I think that you should be fine with a high quality 850W PSU, but, just to be safe, I would get a 1000W PSU, STILL HIGH-QUALITY!!
I recommend checking out some PSU reviews on http://www.jonnyguru.com/
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
@dragoon20005
@Geekazoid
@Mateyyy
