Bit of a problem here...
Go to solution Solved by Norman_the_Owl,
always make sure you have the drivers. B)
That's the thing, literally the first thing i did was download the "Lan drivers" off asus' drivers page for my motherboard.
Anyone know JJ's email so i can send him a strongly worded letter? :P
Edit: Problem solved btw, intel download center is the only good download center i've ever seen
i recently assembled my computer, with the Asus Z-97 pro Wifi AC motherboard. Since then we purchased a new router, dual band, ac. BUT, even though i have my desktop wired with an ethernet cable, it still defaults to the Wifi signal. Is there any reason for this, and how do i fix it? Will be watching the thread for a while, if i left something important out ask.
Edit: using windows 8.1
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/200019-bit-of-a-problem-here/
Are you using Windows 8?
Yes, windows 8.1
https://linustechtips.com/topic/200019-bit-of-a-problem-here/#findComment-2711308
 Go to Control Panel > Network and Internet > Network Connections
Find the wireless signal and click "Disable this network device"
All that did was lock me out of it
https://linustechtips.com/topic/200019-bit-of-a-problem-here/#findComment-2711342
This ^
https://linustechtips.com/topic/200019-bit-of-a-problem-here/#findComment-2711347
Hmm, Well you could try rightclicking the wireless icon, going to network and sharing center, click the wireless connection, then click disable.
https://linustechtips.com/topic/200019-bit-of-a-problem-here/#findComment-2711356
After a bit more looking into it it appears i don't even have the correct drivers for my ethernet.
Get it together asus, and give me the correct downloads next time...
https://linustechtips.com/topic/200019-bit-of-a-problem-here/#findComment-2711414
https://linustechtips.com/topic/200019-bit-of-a-problem-here/#findComment-2711445
