LEDs and other questions
Solved by Enderman,
You shouldn't buy cheap crap LED strips from chine that fail in a couple months. But to answer your questions:
1) no you only need 1 black wire.
2) no you cannot. If you put the molex connectors in parallel it is the same as just using one. If you put them in series you will burn out your power supply. You cannot add more current/voltage to make them brighter when they are connected to molex, because they already running at 100%
Featured Topics
rickymohk ·
Posted in General Discussion1 -
Rbakker02 ·
BaidDSB ·
Posted in General Discussion5 -
1
Mistr J ·
Posted in Troubleshooting3 -
2
4
2
coolbean28 ·
Posted in Graphics Cards8
